R56 Heatshield removal
Old May 24, 2016 | 04:26 PM
Morone's Avatar
Morone
Heatshield removal
Any tips on removing the heatshield? i cant seem to get the bottom 3 bolts out of the upper heat shield ive tried for the past hour
Old May 25, 2016 | 06:12 AM
digitaldagor's Avatar
digitaldagor
I shoved my hand down there and cut it all to crap, but was able to get them out.
Many posts on the forums say to remove the whole front cap. I refused.
Old May 25, 2016 | 08:02 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you talking about the turbo heat shield? If so, we have it on our site under MINI > tech info (tab at top) > R56 articles and then scroll to the bottom under exhausts and click on Catalytic converter Replacement. Might need to spray the bolts down with some PB to help loosen them up.
888.280.7799 | 6am - 5pm PST
Old May 25, 2016 | 10:00 AM
GrayGhost's Avatar
GrayGhost
Thank you Pelican for the tip, I am going to be doing that on Saturday.
Old May 25, 2016 | 10:09 AM
randeez's Avatar
randeez
front three are a pain, on mine as soon as they broke loose i could spin them out by hand the rest of the way. Couldnt get the middle one to line up after swapping dp though so i left it out
Old May 25, 2016 | 10:11 AM
PelicanParts.com
Vendor
You're welcome. Glad I could help.
Old May 31, 2016 | 02:55 AM
GrayGhost's Avatar
GrayGhost
Never mind getting the bolts out. How in the hell do you put them back in???? By far the most frustrating think I have done on my R56.
Old May 31, 2016 | 06:15 AM
randeez's Avatar
randeez
I notched the three bottom holes so I could start the bolts first and slide the shield over them, still a pain. Also a slim 1/4 air ratchet helps install and remove
Old May 31, 2016 | 07:02 AM
MazMini's Avatar
MazMini
I agree when installing my downpipe and muffler it was a total pain in rear... I only put the top portion back on..
Old May 31, 2016 | 09:07 PM
grussell's Avatar
grussell
You don't take the left one out, just loosen it as it has a slot open to the top. I found starting the right one and then flexing the shield to start the middle one worked for me.
Old Jun 1, 2016 | 03:43 PM
BMC_Kid's Avatar
BMC_Kid
It is a PITA to replace it. Instead of replacing it, I just wrapped my downpipe with heat shield exhaust tape. Does a better job and easy to do.
Old Jun 5, 2020 | 11:57 AM
elmerm96's Avatar
elmerm96
Performance effected?
Are there any downsides performance wise to removing the turbo heat shield due to the heat?
Old Jun 5, 2020 | 09:07 PM
elmerm96's Avatar
elmerm96
Does removing the heat shield have any effects to the performance due to the heat or is it really just for show?
Old Jun 6, 2020 | 09:56 PM
Project_Mini's Avatar
Project_Mini
I had my bottom heat shield off for a while but put it back on do to intake temps getting way to high in stop and go traffic. I don’t have a problem now
Old Jun 7, 2020 | 04:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Performance, probably not. However, you run the risk of melting something....
Old Jun 7, 2020 | 07:42 AM
scotty_r56s's Avatar
scotty_r56s
I wrapped my downpipe in DEI Titanium Exhaust Wrap and removed the heat shield. No heat issues or melted stuff on the street or on track. I’ve replaced the upper heat shield with the WMW turbo blanket/heat shield, we’ll see how that holds up on track next month.
Old Nov 13, 2020 | 09:00 PM
troyegly's Avatar
troyegly
How do you like your DP? I just put mine on last night, did a major service and haven't started the car yet. I am waiting for the Forge Turbo Blanket. Both of the heat shields are a total PITA. I should have looked a little bit for the DEI that is a great way to go. How is it holding up?
MCSmoonshine
14
Apr 8, 2023 03:12 PM
madcanvis
Dec 31, 2019 10:30 AM
cstrumol
Sep 29, 2017 06:56 AM
cbryantnyc
14
Dec 31, 2012 02:28 PM
drno
Dec 19, 2008 01:22 PM
