R56 Warning light and rough idle on cold start
Old Jan 5, 2016 | 08:10 AM
tylewis's Avatar
tylewis
I started up my R56 this morning and as soon as I did, I got a high variability in revs. I also had an engine light in the center screen of the Tach. This engine symbol was half filled half empty represented by a 45 degree angle (right side filled solid, left side empty. Apologies for the dismal explanation.
The variability in revs was like I would hit the gas and let off quickly, hit the gas, let off and so on.
It looked like a lot of white smoke but it was 14 degrees out and exhaust and white smoke look identical to me. I think it was just exhaust.
I shut the car off and turned it back on, idles perfectly. Drove it to work, no problems.
The check engine light in the center speedometer never lit up.
What could this be telling me?
Old Jan 5, 2016 | 08:15 AM
nkfry's Avatar
nkfry
Take it to a qualified tech and have the car scanned for codes, they will be stored.
Without that information any diagnostic is going to be impossible.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 6, 2016 | 12:27 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you have a diagnostic tool I would plug into your OBDII and read what code was thrown. Sounds like you had the reduced power indicator. Check out this thread here for some info on the light you were seeing.
888.280.7799 | 6am - 5pm PST
Old Jan 6, 2016 | 06:00 PM
tylewis's Avatar
tylewis
Thank you that helped me a lot. It looks like limp mode is exactly what happened. Maybe it was a malfunction because of the real low temperatures, not sure. Either way this helps.
My ScangaugeII didn't show any codes so I don't know if that's good or bad.
Old Jan 7, 2016 | 08:34 AM
PelicanParts.com
Vendor
You're very welcome. It could maybe be that your scan tool cannot pick up the code that is being thrown or a CEL was not triggered, but not too sure. I'm seeing a lot of different outcomes with somewhat similar symptoms unfortunately. Things such as plugs, HPFP, DME, boost pressure sensor, intake manifold, coolant leak, etc. You could just keep driving it until you have the same issue or you could bring it to an indy shop and see what they might be able to find. I posted some threads below for you to take a look at.
http://www.mini2.com/forum/second-ge...ine-power.html
https://www.northamericanmotoring.co...r-message.html
Old Jan 7, 2016 | 08:47 AM
nkfry's Avatar
nkfry
If you got a half power light there will 100% be codes stored, but Scangauge doesn't read manufacturer specific codes you will need to find someone with a quality scan tool or dealer level computer.
Phone:586-792-6464
Old Jan 7, 2016 | 12:23 PM
GAT's Avatar
GAT
Do you notice that the problem is worse during damp or rainy weather?
Old Jan 9, 2016 | 11:19 PM
akellogg65's Avatar
akellogg65
Bet it's the High Pressure Fuel Pump. My 2011 R56 with 52K started doing this; it threw a code for a misfire, then would clear itself up after about fifteen seconds. Replaced the HPFP today and it's all better now. A mechanic will charge you a grand to fix it. I bought the part and installed in fifteen minutes.
Old Jan 10, 2016 | 10:09 AM
tylewis's Avatar
tylewis
To the above to responses. No I didn't notice anything worse or unusual during wet or damp conditions.
Thank you for making mention of the fuel pump. It might make sense to get that taken care of. I am going to be doing some work on my vehicle soon, maybe I should just knock that out too. I understand that its a common issue with these cars.
The only time this happened was when it was around 12-14 degrees overnight. Definitely the coldest start up this year by far.
Old Jan 10, 2016 | 01:28 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Water frozen in the gas could be a culprit. With those kinds of temps it might be worth it to use some additive for ethanol moisture related issues.
Old Jan 11, 2016 | 09:16 AM
tylewis's Avatar
tylewis
That's an interesting thought. I will try that. Since the time of this originally being posted, I have not run into any issues. It also has not been that cold either.
ottobomb
Off-Topic :: Autos
Jan 10, 2016 08:30 PM
Dec 11, 2015 02:08 PM
piotrus22
Dec 4, 2015 10:31 AM
scf
Dec 1, 2015 10:39 AM
TWISTER
Nov 29, 2015 09:42 AM
