R56 Clutch recommendations?
Old Dec 31, 2015 | 11:19 AM
Nick Royer's Avatar
Nick Royer
My clutch is starting to go and I'm going to be running manic stage 2, what are my best options for performance clutches?
Old Dec 31, 2015 | 02:09 PM
Cooper S :
Clutch master FX100 , it a dual mass to single mass and its steel or alum options.
https://www.ecstuning.com/Mini-2007-...etrain/Clutch/
" • Holding capacity 70% over stock"
Old Dec 31, 2015 | 02:20 PM
EuroTechsAZ's Avatar
EuroTechsAZ
We run stock clutch on all R56's with no issues. We have built several stage 3 or higher R56's with over 300hp and 300trq without issue. We even pushed the E60 fueled Fuel-it/Manic test car to 320wheelTrq on a stock clutch without slipping issues and the car has close to 30k on that clutch. Not too many performance clutches out there have that kind of track record.
Old Dec 31, 2015 | 09:55 PM
BMC_Kid's Avatar
BMC_Kid
Stock clutch? Those are absolute junk. Mine lasted less than 30K. To the OP, get rid of the dual mass flywheel and go with a Kevlar clutch if you are going with a Manic tune. I went with a lightened steel flywheel and a stage 2 Kevlar clutch from JM Turbo Coopers.
Old Jan 2, 2016 | 02:26 PM
oldbrokenwind's Avatar
oldbrokenwind
If you decide on a lightened clutch / flywheel pair, be prepared for inertia loss when launching. A good tune will compensate for this, but if you have a turbo with high RPM boost requirements, like my big Garrett, you're gonna launch like a steamship. I haven't spun tires at launch in over 4 years, since I switched to OS Giken, but I gotta love the acceleration during boost.
Old Jul 17, 2017 | 12:14 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If throwout bearing hadn't gone I'd be on stock original clutch at over 200K miles. Was replaced with OEM at 110K miles, now at 231K miles and still strong as ever.... Typically premature clutch wear has to do more with driver in these cars.
Old Jul 17, 2017 | 01:50 PM
timski's Avatar
timski
231k on a 2nd gen MCS? If that's the original engine I would be impressed.
I have 212k (engine 169k)but car is sitting now for a clutch job.
Old Jul 21, 2017 | 12:25 PM
miniuy's Avatar
miniuy
Totally agree
wkpaz
Feb 3, 2017 06:56 AM
WarEagle
R55 :: Clubman Talk (2008+)
17
Feb 16, 2016 10:39 AM
enoe01
Dec 21, 2015 11:34 AM
Dec 17, 2015 08:37 AM
Minifan85
Dec 15, 2015 08:59 PM
