R56 For those with hi-flow or catless downpipes...
Old Jun 18, 2015 | 02:02 PM
Z06C5R's Avatar
Z06C5R
How are you guys getting through emissions (OBD-II based) with downpipe mods? I have an Akra DP and have used the BMS CAN tool to keep the CEL off thus far, but I just checked for codes using Dashcommand and found that there were two "permanent" O2 efficiency below threshold codes that I could not delete. On top of that, Oxygen sensor monitoring, evaporative system, and catalyst monitoring systems were all "not ready"... I believe that would all add up to a fail in most states that used OBD-II based emissions testing, no?
Old Jun 18, 2015 | 02:33 PM
Systemlord's Avatar
Systemlord
Most uninstall their down pipes and reinstall the OEM hardware before a smog test. Your tool only blocks the CEL from apearing on your dash, it doesn't block the code from being stored. Most tunes program the emissions control system from being able to see the that the primary cat has been removed.
Old Jun 19, 2015 | 07:36 AM
Z06C5R's Avatar
Z06C5R
Any idea why it's showing a "permanent" code? I can't seem to delete it, which makes me think even if I replaced the OE downpipe it would still come up on an OBD scan...
Old Jun 19, 2015 | 09:11 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 Well said.
Not sure if I am reading this right, but it will permanently stay on unless you get a tune that codes it out, or do a spacer for the O2 sensor (sometimes works/sometimes doesn't). If you put the OE downpipe back on and reset the code, it shouldn't come back.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 20, 2015 | 11:00 AM
Z06C5R's Avatar
Z06C5R
The diagnostic function within Dashcommand has three fields into which it populates codes: Pending, current, and permanent. Pending and current make sense, but I'd never heard of a permanent code prior to using the app. Clearing codes using either Dashcommand or my CAN tool will get rid of the pending and current codes, but permanent codes remain. Not sure what to make of it, or whether this is even something an OBD-II emissions inspections would look at.
Old Jun 20, 2015 | 05:45 PM
minivinnie92's Avatar
minivinnie92
I run manic and it blocks the o2 from running it's readiness monitor I have personally checked with my scanner that seems the best I will fly right through emissions
Old Aug 9, 2016 | 01:00 PM
dez's Avatar
dez
Sorry to revive an old thread, but minivinnie92 any update since this post? Have you had to go through a smog check yet?
Old Aug 9, 2016 | 02:14 PM
minivinnie92
I actually just past nj state inspection this past week or so
New Jersey is just and obdII scan so now tailpipe sniffer I had new issues
Old Aug 9, 2016 | 03:02 PM
dez's Avatar
dez
Thanks.
Hope mine goes that easy. Thinking about doing a "Smog Pre-Test"
Old Aug 9, 2016 | 04:47 PM
minivinnie92
Where are you located? Usually if u fail it's a lot harder to get through
Old Aug 9, 2016 | 05:08 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by dez
Thanks. Hope mine goes that easy. Thinking about doing a "Smog Pre-Test"
I passed in CA with my GP2 set up
mQubed Motorsport, Manic Tuning Dealer
Attached Thumbnails For those with hi-flow or catless downpipes...-image-2014477414.jpg
Old Aug 9, 2016 | 09:01 PM
Sstrickstein's Avatar
Sstrickstein
I have a Riss Racing down pipe and I run a Accesport. The monitors are all set and no codes. The programming works around the CEL and sets the monitors anyway.
Old Aug 10, 2016 | 07:54 AM
dez's Avatar
dez
I'm in CA. The pre-test is an off the record test and the results are not transmitted to the governing body.
Mario, you already had to SMOG the GP2?
Old Aug 10, 2016 | 03:23 PM
MarkUSAF's Avatar
MarkUSAF
I solved that problem by moving from VA to Florida...no inspections here!
Ovrclck
Oct 5, 2015 09:45 AM
GAT
Oct 4, 2015 07:27 PM
potterstein
Oct 2, 2015 09:30 AM
potterstein
Oct 1, 2015 07:10 AM
Aug 27, 2015 03:18 PM
