R56 Shifting hard and CEL
Old Aug 10, 2016 | 02:58 PM
NikiMae31's Avatar
NikiMae31
So a couple days ago I put in an Alta hot side tube on my 2008 automatic MCS. Felt great after that. Today it seems like its shifting harder in the lower gears and the CEL just came on. Any ideas if they are related? I think I'll have the code pulled tomorrow. It is running okay besides that.
Anyone's thoughts would be great.
Old Aug 10, 2016 | 05:06 PM
Mini Mania's Avatar
R56 Shifting Hard
Shifting probably unrelated. Check your slave cylinder for leaking. Also the lower engine and transmission mounts. Very likely the shift linkage which might need some lithium grease.
Please let us know what you find out!
Old Aug 10, 2016 | 05:13 PM
NikiMae31's Avatar
NikiMae31
In driving it home, it seems like the turbo isn't kicking in instead of it shifting hard. Just not the power I normally got when putting my foot down on the gas. I'm going to throw it up on my ramps tomorrow to check for any air leaks in the tubes I put in. Hoping the turbo isn't blown..
Old Aug 10, 2016 | 05:46 PM
3lusive's Avatar
3lusive
I had something like this happen to me, the car felt very sluggish after accelerating hard on an offramp. It definitely felt like the turbo was not there. In my case the intake pipe that connects the intercooler on the left hand side of the engine (looking at it from the front of the car, the one you can see just left of the timing chain housing) had been disconnected because I failed to tighten it back up sufficiently. At any point in the intercooler piping I could see how a leak like that would cause a similar behavior as what you are seeing. Turbo is probably fine, just check for leaks!
SpuuDy
Nov 7, 2016 08:56 AM
Jimmy Devaney
Apr 18, 2016 01:02 PM
Beaudog
Apr 4, 2016 02:43 PM
MikeD
Sep 4, 2008 08:10 AM
Cooperman
26
Oct 9, 2002 03:55 PM
