R56 2011 Justa Check Engine light
Old Feb 18, 2015 | 05:53 PM
raday's Avatar
raday
This morning, on the way to work, the yellow CEL came on. The temp outside in the 20's F, Ice on the roads and piled high. I was scraping some of it. I checked the oil, and the coolant level. The coolant is slightly below minimum on the jug, but oil is good. I tried disconnecting the battery to reset the CEL, but it did not reset. I looked under the car and could see nothing hanging down or leaking.
My question is could the low coolant cause the CEL? I have less than 50,000 miles on the car and the active date is in May, so I think it is still under warranty.
Thanks in advance for the help.
raday
Old Feb 18, 2015 | 10:01 PM
Zillon's Avatar
Zillon
Head to a local Autozone or Advance Auto parts and have them read the codes.
It'll tell you what caused the CEL.
Old Feb 19, 2015 | 03:41 AM
raday's Avatar
raday
OK, Thanks. I will check it out.
raday
Old Feb 19, 2015 | 01:31 PM
raday's Avatar
raday
Well, I planned on going to the mini dealer after work, but I guess the fear of the mini dealer put the scare into the CEL and it was not on when I started the car this afternoon.
Thanks for your response.
raday
Old Feb 19, 2015 | 01:38 PM
rckrzy1's Avatar
rckrzy1
raday
I would still have it checked, as it maybe the sign of something failing and very posibly will return. I'd want to catch it before the warranty expires.
Seriously a cheap code reader can be bought for $10-$20 now a days, I don't understand why everyone does not have one. Kinda hard to guess anything with cars anymore.
Old Feb 19, 2015 | 09:06 PM
Zillon's Avatar
Zillon
Buy the Torque app for your phone and get a bluetooth or wifi dongle to use with it. It'll allow you to read and clear codes on your own time.
Old Feb 20, 2015 | 05:13 AM
pfarinelli's Avatar
pfarinelli
I would like to get the app and the Bluetooth device for my Mini. Which dongle did you purchase?
Old Feb 20, 2015 | 08:23 AM
Zillon's Avatar
Zillon
This is the one I have:
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
Just be aware it's Android only.
Old Feb 20, 2015 | 05:16 PM
DOtheDEW's Avatar
DOtheDEW
is your mini an automatic or standard? were you caught in snow briefly and had to push the car a little hard to get it out?
Old Feb 22, 2015 | 03:48 AM
pfarinelli's Avatar
pfarinelli
Thanks for the info however, I need one that will function with Apple. I think eBay may be my friend on this one.
Old Feb 22, 2015 | 05:28 AM
danjreed's Avatar
danjreed
Be aware that some check engine lights are BMW only readable with a proper "factory" scan tool.
(These are the half/power/lit check engine lights).
Full blown check engine lights can be read with a generic aftermarket scan tool.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
