R56 Back in the shop!
Old Feb 10, 2015 | 01:57 PM
sabrownfl's Avatar
sabrownfl
Back in the shop!
One month of ownership and my car is in the shop for the second time. :-(
This time I got a CEL on the way to work. Used the code reader (hoping for something simple like a loose gas cap) and got P012 CAMSHAFT Bank A Over Retard.
At the dealer service department now so we will see what happens.
Seriously missing the typical Japanese reliability of my Miata right now.
Old Feb 10, 2015 | 04:24 PM
sabrownfl's Avatar
sabrownfl
Back on the road, no charge for service. Techs hooked up computer, and found fault 2D5A- Vanos: Intake Control Fault. Ran full test, and drove vehicle after resetting code, not further issues.
I've been told to "monitor vehicle for CEL" and return as needed.
My confidence is high that I'll be back.
Old Feb 10, 2015 | 05:38 PM
AZdsrt's Avatar
AZdsrt
Ya, you'll probably be back. Am surprised they didn't replace the VANOS solenoid. The intake solenoid on mine failed, would give me occasional CEL, so I finally had it replaced.
Old Feb 10, 2015 | 07:38 PM
sabrownfl's Avatar
sabrownfl
I am hoping there are no more problems but I guess I will be prepared.
The advisor did say that if it happens again they will dig deeper. I had no appointment so I am happy that they at least got me in to take a look.
Old Feb 11, 2015 | 12:45 PM
nkfry's Avatar
nkfry
We have run into the same issue, and with some cars we are able to clean the VANOS solenoid and reinstall it, but with others we have replaced them.
If this doesn't fix your issue, you may be in for a timing cassette.
Good Luck,
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 11, 2015 | 05:22 PM
sabrownfl's Avatar
sabrownfl
Good Luck,
Nick
Detroit Tuned
Thanks! Is the solenoid something I can do at home, or is it "major surgery"? I have a pretty fair mechanical knowledge, but my tool-set is limited.
The SA did mention "programming" if it came back on... That seemed odd, but I figured they were the experts.
Old Feb 11, 2015 | 05:41 PM
nkfry's Avatar
nkfry
Remove the airbox, as well as the intake pipe to the throttle body (this is a possibility) I've done it with the pipe in place, but access makes every job easier. And the solenoid is right above the tensioner and is held in by one 10mm bolt, give it a strong tug to break the o-ring tension and it'll pop right out.
Programming is slang for milking your wallet.
Phone:586-792-6464
Old Feb 11, 2015 | 08:29 PM
sabrownfl's Avatar
sabrownfl
Thank you. Sounds doable, if the light comes on again I'll give it a go.
I'm not under warranty, so any visit to the dealer service department could be costly, although as of yet I'm not out a dime for my visits... I'm lucky!
Old Feb 13, 2015 | 06:07 AM
richardsperry's Avatar
richardsperry
Find a good independent MINI mechanic. There is no reason to pay the ridiculous dealer shop labor charges...
Old Dec 9, 2015 | 12:25 PM
sabrownfl's Avatar
sabrownfl
Here we go again...
Driving to work this morning, and the half-power CEL pops. Use the handy dandy code reader, P0012- Powertrain "A" Camshaft Position- Timing Over-retarded (Bank 1).
Had to take care of some things, and when I got back to the car and fired it up, the CEL was out, and it ran fine. Since I just had the HPFP replaced two weeks ago, I'm light on cash, so I'll drive it until the weekend, and see if I have any other incidents.
I'm sure it is the intake solenoid again, so I'll likely replace it this time. Should I do both intake and exhaust at the same time, or is that a waste of time and money?
Old Dec 10, 2015 | 09:52 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check out this thread HERE. Multiple individuals indicate they had to replace the VANOS solenoid. Have it here if needed. My suggestion is if you have determined you need a VANOS solenoid by cleaning or swapping side to side, replace both solenoids. They are fairly inexpensive and you're always better off replacing a degrading part. We go over all of this in our VANOS DIY.
888.280.7799 | 6am - 5pm PST
Old Dec 11, 2015 | 05:10 AM
sabrownfl's Avatar
sabrownfl
You can clean the screen on the Solenoid Valves first. 11368610388 Sometimes using certain oil filters that lint will do this. Had no issue with ours.
Solenoid has been cleaned once, by the dealer, back in February just three weeks after I bought the car. I have the oil changed every 4k to 5k miles by a small private shop that specializes in MINI work. Not sure what brand filter they use, but I'll ask.
I'm going to do the solenoid replacement myself if the light pops again. It went off on its own for now, but I'm sure it will return soon.
Old Dec 11, 2015 | 05:11 AM
sabrownfl's Avatar
sabrownfl
I've looked over the tutorials, and I can handle the replacement. I see you mention not re-using the fasteners... Do new ones come with the new parts?
Old Dec 11, 2015 | 07:56 AM
PelicanParts.com
Vendor
Correct. Replace the fastener and O-ring every time the sensor is removed from the cylinder head. As the tech article states be sure to lubricate the O-ring with clean engine oil to facilitate installation. The new solenoid comes with the o-ring. The 10mm fastener is here (click on more info). #7 below. Let me know if you have any other questions.
surfblue
Oct 24, 2018 01:20 AM
Steeroidz
Aug 29, 2018 07:41 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
beemboy
Northern California
Aug 19, 2015 02:00 PM
Minibeagle
Aug 13, 2015 10:00 AM
