R56 Hid projectors installed. A++++
Old Jan 16, 2015 | 12:10 PM
erjon's Avatar
erjon
Hello guys.
I just wanted to share with you that i have installed Morimoto H1 projectors onto my Mini One D 2009 LHD. I did not cut anything. For opening the headlights i just used an hair dry and it was prety easy. I did had some problems only for mounting them, but it did installed good. Is not the perfect solution without cuting, but i was sadisfated with the results. Sorry that i did not take any photo of setup, but i can share only informations that H1 can be installed, and no cut is involted. This is also an experience for opening headlights.
Attached Thumbnails Hid projectors installed. A++++-img_2927.jpg   Hid projectors installed. A++++-img_2926.jpg   Hid projectors installed. A++++-img_2924.jpg   Hid projectors installed. A++++-img_2923.jpg   Hid projectors installed. A++++-img_2922.jpg
Hid projectors installed. A++++-img_2921.jpg   Hid projectors installed. A++++-img_2920.jpg   Hid projectors installed. A++++-img_2919.jpg
Old Jan 16, 2015 | 01:34 PM
Centium's Avatar
Centium
Where did you buy the kit? I found them on eBay for $150...
Old Jan 16, 2015 | 01:36 PM
erjon's Avatar
erjon
Hid projectors with mini gatling gun are from theretrofitsource.com
Old Jan 16, 2015 | 07:29 PM
minivinnie92's Avatar
minivinnie92
What bulbs did you use?
Old Jan 17, 2015 | 01:35 AM
erjon's Avatar
erjon
I have used H1 bulb.
Old Jan 17, 2015 | 09:27 AM
erjon's Avatar
erjon
Before installing Morimoto mini H1 with H1 bulb, i had hid kit with H4 bi-xenon bulb. I changed only the bulb with the H1 which did came with hid projectors. Ballasts and relay harness are the same.
Old Jan 17, 2015 | 09:38 AM
minivinnie92
So you used the hid kit from theretrofitsource? No bulb out warning or nothing?
Old Jan 17, 2015 | 09:43 AM
erjon's Avatar
erjon
No my friend. First i have installed hid kit with H4 bulb which i have ordered from ebay for 100 USD including shipping to my country. A month after i have ordered only hid projectors and H1 bulb from TRS which did cost 160 USD including shipping with 23 usd discount at that time. I know most of us think how to convert existing setup with H4 bulb to H1 bulb. It was simple. H4 bulb use 3 connections. The smallest one, which in H4 bulb is the high beam, has to be connected to solenoid in hid projector. I had bulb out warning, cause you cannot find a special canbus for our mini. i had to program to disable hot and cold monitoring for my mini. but you can always use a capacitors for this problem.
Old Jan 17, 2015 | 09:46 AM
erjon's Avatar
erjon
For the hid kit i would recommend the full kit from TRS, cause the kit i ordered from ebay caused me troubles. Company did send me 3 kits, cause one had problem with one ballast in begining, the second had problem with bulb, high beam on always, and now i am at 3-rd kit. Better spare headache and go for full kit for 270 usd. I have read many good story with TRS (theretrofitsource) ballasts, go for them.
Old Jan 17, 2015 | 03:54 PM
minivinnie92
Ah ok gotcha was just trying to grasp everything sorry for the confusion I will look into it
Old Jan 17, 2015 | 04:14 PM
two250's Avatar
two250
Looks great, I want to retrofit my halogens to HIDs so badly...
Old Jan 17, 2015 | 07:11 PM
minivinnie92
Me too especially if I don't have to program anything that'd be awesome
Old Jan 18, 2015 | 12:23 PM
erjon's Avatar
erjon
Well if you don't want to program, you can use diodes like below. Normaly canbus ballast should not through any bulb out warning in US model, but in my europian model it did, so since i had dcan cable and ncs expert, i did program it. You can install hid projectors. It is more simple that it look. And i can say, the difference is huge. Also don't forget to exchange fog light with led canbus one, i mean w5w bulb. They are great.
Old Jan 18, 2015 | 12:25 PM
erjon's Avatar
erjon
http://www.hidplanet.com/forums/atta...6&d=1374433958
Old Jan 22, 2015 | 12:06 AM
Centium's Avatar
Centium
Any chance you could post dome detailed pictures of the back of the headlamp housings as well as the wiring harness and ballasts?
Old Jan 22, 2015 | 01:01 AM
erjon's Avatar
erjon
I will try to do my best. You have just to remember that when ordering the harness, it should be for H4, but the bulb should be H1 cause Hid projector will use only H1 bulb, and harness needs to be H4 cause original wiring is for H4.
Old Jan 22, 2015 | 06:21 AM
Centium's Avatar
Centium
H4? On my 2011 MCS it's H13 (9008)... But I understand what you're saying. I know how to wire them up, I'm more interested in the Morimoto Projector installation and where you've put your ballast to get an idea of where I might put mine.
Old Jan 22, 2015 | 10:26 AM
minivinnie92
I am in the same boat I also have an 11 with h13 and I'm looking for the same thing would like to see how the projectors are attached
Old Apr 27, 2015 | 04:56 AM
rlmd09's Avatar
rlmd09
Hi, I had some questions for you on how you did this:
When you say no cutting do you mean you did not cut the reflector or projector shroud?
Did you mount the projector to the reflector using the locking screw on method?
How did you aim and adjust the projector?
Is there a gap between the reflector and shroud?
Can you post some closeup pics of the reflector and shroud?
RL
Originally Posted by erjon
Hello guys.
YouTube
Old Apr 27, 2015 | 10:04 AM
erjon's Avatar
erjon
With no cuting involted i mean cut on reflector, but for sure the shroud need to be cut in its base. Aiming was after putting it on with car on. You can rotate the reflector, and for vertical or horizontal aim you can use the + buttons on the house to aim them.
RL
OutMotoring
Nov 16, 2015 07:04 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
