R56 Replaced Water pump and thermostat
Old Nov 25, 2014 | 05:41 PM
cmamon's Avatar
cmamon
A few months ago, I replaced the water pump on my 2008 MCS with 96,000 miles on it. It was running fine and 2 weeks ago, my check engine light came on. I went to Autozone and they said the code was P0597, So I ordered a new thermostat and replaced it. In the process, I pulled the water pipe out of the other side where it connects to the water pump, so I just pushed it back in, finished installing the thermostat and refilled the coolant. The check engine light was still on when I finished it so I took it to Checker and they said it was code P0597 and p0118. Now, it makes a sound like something is brushing against something else on the side with the water pump. When I start it in the morning, the check engine light is on, it idles rough and has a hard time getting going... But once it warms up, it runs fine. Any ideas what it could be? Maybe the water pipe went too far into the water pump? I have no idea. I've disconnected and reconnected the wire connectors several times. Thanks!
Old Nov 27, 2014 | 09:03 AM
afadeev's Avatar
afadeev
P0597 = Thermostat heater control circuit / open
P0118 = Engine Coolant Temperature Circuit High
Lets start with the obvious.
Reset all check engine lights before proceeding, otherwise old lights may be confusing your debugging efforts.
Possibilities:
1). What is brushing against what - is it just the normal serpentine belt noise, or something else? Track the source and remedy!
2). Did you use an original OEM thermostat, or something off eBay ?
3). Are you sure you plugged all the harness plugs correctly, especially to the Coolant Temperature Sensor (CTS) ?
My bet is on either a bad CTS, or a bad replacement thermostat.
HTH,
a
Old Nov 27, 2014 | 04:47 PM
cmamon's Avatar
cmamon
I'm not sure whats making the sound.. It sounds like its from the belt or water pump.
I bought my thermostat from ECSTuning. It says it's genuine MINI. http://www.ecstuning.com/Mini-2008-C...ostat/ES25098/
I recheked the plugs and I put the temp sensor from the old one back in. I'll see how it starts in the morning since it'll be cold.
Old Dec 5, 2014 | 02:01 PM
Unplug them and plug they back in they snap in. Its a genuine MINI Part for OES and of course the genuine. We had only one thermo sensor go bad in a very long time factory. Also make sure you filled the coolant all the way up and have all the air out. Bleed , bleed , bleed. If the coolant is low in the thermo you can get a sensor error.
Thermostat Replacement Kit 11537534521
http://www.ecstuning.com/Search/SiteSearch/11537534521KT/
Check for item that fell near the pulley for the water pump of the fiction pulley, sometimes makes noise when it gets coolant on it. See DIY.
DIY Here:
https://www.northamericanmotoring.co...8-no-heat.html
Old Dec 10, 2014 | 09:12 AM
bugeye1031's Avatar
bugeye1031
Moderator
Were you able to identify the issue(s)?
I have a similar problem and would appreciate knowing what you found....
Old Dec 10, 2014 | 09:57 AM
cmamon's Avatar
cmamon
I haven't found anything out yet. I go in to a mechanic tomorrow morning for them to test it. Ill let you know what they say.
Old Dec 19, 2014 | 12:37 PM
Any update?
Old Dec 19, 2014 | 06:36 PM
cmamon's Avatar
cmamon
Hey sorry for now replying. The mechanic said that I had 2 electrical plugs reversed. Im pisitive I had all the colors matched. Paid $100 for them to tell me that haha. Anyway, now it runs perfect.
Old Dec 22, 2014 | 05:01 AM
Glad you got it fixed.
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
gmonde
Sep 8, 2015 06:37 AM
kwijmbo
Aug 5, 2015 09:00 PM
