R56 Timing Chain has 126k miles
Old Nov 12, 2014 | 06:58 PM
bugeye1031's Avatar
bugeye1031
Moderator
I'm trying to decide if I should replace my timing chain, water pump, etc. before or after the holidays. Any thoughts would be appreciated.
-2009 S - original owner
-126,000 miles - my commute is 72 miles per day, mostly at about 75 mph
-oil changes at 5,000 miles, with regular top-ups between changes
-I don't drive it hard - no track days
-The original timing chain, guides, water pump, etc. still hard at work
-I just measured the chain slack and it's at 68mm. I put in the longer tensioner. The original tensioner was replaced under warranty at about 20k due to the death rattle.
-There is more noise than I'd like, but there is no death rattle
-I just replaced the thermostat housing, replaced the valve cover at about 115k, still on the original turbo oil line
The family needs to take a trip over the holidays, and I'm thinking that I should go through and replace the timing chain "kit" (including the sprockets, crank seal, guide rails, etc), water pump, friction wheel, serpentine belt, and serpentine belt tensioner now. Am I living on borrowed time?!
Old Nov 13, 2014 | 07:28 AM
Zillon's Avatar
Zillon
To be honest, I'd probably do the same if I was looking to keep the car long-term.
Your preventative maintenance has definitely helped the chain and guides last this long, though - the 5k oil changes and tensioner replacement are key.
Old Nov 13, 2014 | 08:14 PM
jcauseyfd's Avatar
jcauseyfd
If it ain't broke, I wouldn't bother trying to do all that work.
I doubt the 5k OCI has helped with the chain's life.
Old Nov 13, 2014 | 10:26 PM
Porthos's Avatar
Porthos
Bam! Right there.
Old Nov 13, 2014 | 10:34 PM
Zillon's Avatar
Zillon
Believe what you want - on these engines I think 5k is better than whenever the OBC tells you to.
Between sludge issues, oil consumption, etc., it's just better to change it sooner rather than later.
Old Nov 14, 2014 | 09:14 PM
Systemlord's Avatar
Systemlord
It doesn't cost much to change your oil ($25 Mobil 1 Walmart/oil filter OEM $9) these days especially if you do it yourself. I have a marine pump that sucks all the oil through the oil dip stick tube into a storage container that holds up to 6 quarts.
Cheap insurance.
Old Nov 14, 2014 | 09:51 PM
Zillon's Avatar
Zillon
Cheap insurance.
This guy gets it.
Old Nov 14, 2014 | 10:22 PM
renchjeep's Avatar
renchjeep
5k oil changes and only 68mm deflection would make me keep going. I see no reason to replace anything, unless it makes you feel better. That being said, I feel better when I can't quite get to 5000 miles, and change my oil and filter just because it's close! My Mini should last for a long time, and whoever buys it used someday will get one sweet little "babied" car!
Old Nov 14, 2014 | 10:27 PM
renchjeep's Avatar
renchjeep
More noise than normal? That might concern me some. But knowing that direct-injection is noisy, no worries! Just maybe "you", looking for problems? I know that I do NOT like the direct-injection noise, but have come to accept it as normal.
Old Nov 20, 2014 | 09:25 AM
bugeye1031's Avatar
bugeye1031
Moderator
Decided to make the change
Thanks for all the input. I decided to make the change. I had my indy BMW/MINI mechanic listen to it and he said that the timing chain was making more noise than it should but it didn't sound horrible. I decided to play it safe.
I have no idea if changing the oil every 5k helps with the timing chain, but there is no way that I'm ever going much longer than that before changing my oil....I intend to keep this car for awhile.
Old Nov 20, 2014 | 10:59 AM
chappybmode's Avatar
chappybmode
did you do the work or have it done?
Old Nov 20, 2014 | 04:41 PM
bugeye1031's Avatar
bugeye1031
Moderator
I had planned on doing it (bought the tools), but after talking to Chad at Detroit Tuned I decided that I'd play it safe and have it done professionally. I'll post the costs and results when it's done.
Old Nov 20, 2014 | 04:58 PM
danjreed's Avatar
danjreed
Cheap insurance.
This,,, this... ALL DAY LONG.
Old Nov 26, 2014 | 04:00 AM
tsa1's Avatar
tsa1
you got very lucky with your mini! does it have the oil filter housing leak?
Old Nov 26, 2014 | 07:49 AM
Club77's Avatar
Club77
Does N18 engine have this Timming chain issue?
Old Nov 26, 2014 | 08:35 AM
HotChickenStrips's Avatar
HotChickenStrips
I believe the N18 had the updated timing chain cassette and tensioner to adress the horrible noise and possible timing jumping.
We've done a couple here at the shop and both were N14 engines.
I tell ya, when the timing jumps, it ain't pretty....or cheap.
Old Nov 26, 2014 | 10:21 AM
Ovrclck's Avatar
Ovrclck
My 2010 MCS chain and tensioner was replaced in May at 39k miles but it's starting to get noisy again(49k)..Should I be worried? lol
Old Nov 26, 2014 | 05:58 PM
bugeye1031's Avatar
bugeye1031
Moderator
No oil filter housing leak..and no turbo oil line leak.
Old Nov 26, 2014 | 06:09 PM
Club77's Avatar
Club77
Originally Posted by HotChickenStrips
I believe the N18 had the updated timing chain cassette and tensioner to adress the horrible noise and possible timing jumping. We've done a couple here at the shop and both were N14 engines. I tell ya, when the timing jumps, it ain't pretty....or cheap.
Grade to hear that.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
Aug 12, 2015 01:24 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
