R56 Intake Manifold Spacer
Old Dec 14, 2014 | 10:30 PM
  #151
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by Agbullet25
Sure would like to know what the hell crawled up Sprintcars' butt.
He seems a little on edge and has deleted his post.
mQubed Motorsport, Manic Tuning Dealer
Old Dec 14, 2014 | 10:32 PM
  #152
Agbullet25's Avatar
Agbullet25
True but not the follow ups. Side note, did my notes help you get the dimmer wire done up?
Old Dec 14, 2014 | 10:33 PM
  #153
MarioKart's Avatar
MarioKart
Vendor
They did, it all works, just need to spend sometime fine tuning the kit. I'm loving the low IAT's at full boost
Thanks for your hep
Old Dec 14, 2014 | 10:35 PM
  #154
Agbullet25's Avatar
Agbullet25
Thanks for your hep
Excellent. I'll be following your advice and hints when it comes time to install my system this summer.
Old Dec 14, 2014 | 10:46 PM
  #155
MarioKart's Avatar
MarioKart
Vendor
The Aquamist kit seems kinda impressive at first, but it comes with everything and is the most plug/play system designed for our Mini's
BTW, why do all my picture post grainy now. I haven't changed my APP settings.
Attached Thumbnails Intake Manifold Spacer-image-1331812877.jpg   Intake Manifold Spacer-image-3569192188.jpg   Intake Manifold Spacer-image-998144284.jpg   Intake Manifold Spacer-image-3036676234.jpg   Intake Manifold Spacer-image-3629823782.jpg
Intake Manifold Spacer-image-174421239.jpg   Intake Manifold Spacer-image-556972597.jpg
Old Dec 14, 2014 | 11:20 PM
  #156
Systemlord's Avatar
Systemlord
You're not the only one, he turns on you like a wild rabid animal!
Old Dec 14, 2014 | 11:33 PM
  #157
Systemlord's Avatar
Systemlord
A little on edge is putting it mildly! He seems a bit dramatic and canceling his membership which he didn't follow through with, highly unpredictable and very hostile.
Old Dec 15, 2014 | 03:18 AM
  #158
scubbysnacks's Avatar
scubbysnacks
Oh behave
Attached Thumbnails Intake Manifold Spacer-austin_danger_powers_mike_myers.jpg
Old Dec 15, 2014 | 07:15 AM
  #159
SPRINTCARS's Avatar
SPRINTCARS
Actually there is no problem at all. I was simply trying to avoid exactly what happened by stating I'll PM someone's name and mr Mario decided to take it where I chose not to so I just asked a question. By looking at the photos posted it was clearly obvious that was his exact point as I asked him. Then two others feel offended. If your offende by someone asking questions,
OH WELL
Old Dec 15, 2014 | 08:48 AM
  #160
AWD_Rally's Avatar
AWD_Rally
Moderator
Veteran: Marine Corp
So... Back on topic...
Any back to back dynos yet?
Old Dec 15, 2014 | 08:50 AM
  #161
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by AWD_Rally
So... Back on topic... Any back to back dynos yet?
Exactly.
  #162
AWD_Rally's Avatar
AWD_Rally
Moderator
What do you think about cooling mist? Had their kit for my sti, good stuff. Iwonder if it's just as easy plug and play like Aquamist?
Old Dec 15, 2014 | 09:22 AM
  #163
MarioKart's Avatar
MarioKart
Vendor
I have had 3 CoolingMist before, and they work well, but they were not quite and integrated as the Aquamist, or the gauge. What ever kit you choose, it will work and the number to hit is 500cc/min.
Old Dec 15, 2014 | 09:42 AM
  #164
SPRINTCARS's Avatar
SPRINTCARS
Off topic. This threads about an intake spacer.
Old Dec 15, 2014 | 09:54 AM
  #165
MarioKart's Avatar
MarioKart
Vendor
Sorry, back on Topic
I'm not a fan of the functionality of the spacer, but it does look badass
Old Dec 15, 2014 | 01:56 PM
  #166
AWD_Rally's Avatar
AWD_Rally
Moderator
Does it actually improve anything?in any way? Other than the manufacturers dyno.
Old Dec 15, 2014 | 02:51 PM
  #167
Agbullet25's Avatar
Agbullet25
I think that's the biggest question. No one seems to have a conclusive answer.
Old Dec 15, 2014 | 03:22 PM
  #168
SPRINTCARS's Avatar
SPRINTCARS
There changing the intake runner length correct ? On a pressurized system lengthening the runner does not have and affect on the engine like a naturally aspirated engine does.
http://auto.howstuffworks.com/question517.htm
Hope that article helps ya.
Old Dec 15, 2014 | 03:59 PM
  #169
AWD_Rally's Avatar
AWD_Rally
Moderator
So.... I need 10 ft of spacers asap! haha
Old Dec 15, 2014 | 04:05 PM
  #170
MarioKart's Avatar
MarioKart
Vendor
I will just up my boost .01PSI
Old Dec 15, 2014 | 04:12 PM
  #171
SPRINTCARS's Avatar
SPRINTCARS
Basically, yes. That's what it would be about. Every motor requires different length intake runners for a given rpm range. The basic rule of thumb is
short runner for top end.
Long runner bottom end
Big cc ports for higher rpm
Smaller cc ports for low rpm.
Cubic or liters plays a role in size. To big, it's a wide open engine. To small, never get to max rpm and make good power.
My question to the developer would be, how did you come up with this motor needs this length runner ?
Now make it a pressurized system, all that changes. Pressurized wants better flow design port and bigger valves so more cfm can be moved. Not length.
Old Dec 15, 2014 | 04:20 PM
  #172
Agbullet25's Avatar
Agbullet25
Is it possible that by adding the spacer, it "smoothes" out the airflow coming from the manifold into the head?
Old Dec 15, 2014 | 04:23 PM
  #173
SPRINTCARS's Avatar
SPRINTCARS
Basically, yes. That's what it would be about. Every motor requires different length intake runners for a given rpm range. The basic rule of thumb is short runner for top end. Long runner bottom end Big cc ports for higher rpm Smaller cc ports for low rpm. Cubic or liters plays a role in size. To big, it's a wide open engine. To small, never get to max rpm and make good power. My question to the developer would be, how did you come up with this motor needs this length runner ? Now make it a pressurized system, all that changes. Pressurized wants better flow design port and bigger valves so more cfm can be moved. Not length.
On a mechanical fuel injection, SBC, the general rule is every 2 inches when tuning the intake.
I'm willing to bet, after building that motor of mine for the second time ground up, after seeing BMW's design/engineering. It's pretty damn close as it is. Unless your gonna increase the high rpm range by 2000 rpm, I seriously doubt that spacer alone will make a difference if any. Like Mario said. Increase boost by .01.
Old Dec 15, 2014 | 04:58 PM
  #174
MarioKart's Avatar
MarioKart
Vendor
On a mechanical fuel injection, SBC, the general rule is every 2 inches when tuning the intake. I'm willing to bet, after building that motor of mine for the second time ground up, after seeing BMW's design/engineering. It's pretty damn close as it is. Unless your gonna increase the high rpm range by 2000 rpm, I seriously doubt that spacer alone will make a difference if any. Like Mario said. Increase boost by .01.
Thank you for providing the information. I admit when I first saw the spacer, I was hoping for something new and worth while, but it's looking to be neither good or bad
Old Dec 15, 2014 | 05:06 PM
  #175
SPRINTCARS's Avatar
SPRINTCARS
Thank you for providing the information. I admit when I first saw the spacer, I was hoping for something new and worth while, but it's looking to be neither good or bad mQubed Motorsport, Manic Tuning Dealer
It's got but 3 uses, meth injection, nitrous injection or major headache
