R56 Intake Manifold Spacer
Old Oct 3, 2014 | 01:19 PM
  #101
EuroTechsAZ's Avatar
EuroTechsAZ
Originally Posted by Grizld700
Awesome! Is that a Meth system I see there?
yes sir , We have been working with Nick at Manic on putting this kit together. This is the prototype system so it may be a little bit before we see it up for sale but it is happening.
Old Oct 3, 2014 | 01:25 PM
  #102
SPRINTCARS's Avatar
SPRINTCARS
Im in !!
Old Oct 3, 2014 | 01:26 PM
  #103
SPRINTCARS's Avatar
SPRINTCARS
NO !! Wait. Move them slightly to the side so I can put something next to them. 😬
Old Oct 3, 2014 | 01:56 PM
  #104
cerenkov's Avatar
cerenkov
It turns out that I am getting a little bit of rubbing on the upper passenger side corner of the airbox. Anyone else experiencing this. I have remove the spacer for the time being.
Old Oct 3, 2014 | 02:00 PM
  #105
Grizld700's Avatar
Grizld700
Rut row raggy
Old Oct 3, 2014 | 02:32 PM
  #106
bmwr606's Avatar
bmwr606
Originally Posted by u238
VANOS is the timing though, not lift.
to clarify .... there is a vanos screen that shows current valve timing and lift on the tool
Old Oct 3, 2014 | 06:16 PM
  #107
redparchel's Avatar
redparchel
Originally Posted by EuroTechsAZ
My spacer is going to make more than 10 hp.
Dyno numbers coming soon after i get the correct nozzles. Center 2 are mock up at the moment.
Ya know I had a similar idea to use the spacer the same way. However I couldn't get pasted all the conflicting info about directly spaying into each cylinder vs farther back in the intake system on our cars. Do you mind explaining the idea concept behind your idea?
Old Oct 3, 2014 | 06:27 PM
  #108
cerenkov's Avatar
cerenkov
Originally Posted by SPRINTCARS
NO !! Wait. Move them slightly to the side so I can put something next to them. dde2c
What are you planning?
Old Oct 3, 2014 | 07:11 PM
  #109
EuroTechsAZ
No concept. Direct injection is the safest method of delivering water/meth into an intake that is only designed to flow air. If you ever get a chance to pull an intake manifold on the N14 you will see more carbon build up on the #3 and #4 cylinders. This is due to uneven flow of oil vapor through the intake manifold. This uneven flow would apply to a mist of water meth the same.
Old Oct 3, 2014 | 08:30 PM
  #110
Roxspin72's Avatar
Roxspin72
I'm in, let's make this happen. From what I see it's all about purchasing said spacer, shipping to said fabricator, mock up a direct port delivery system and Bam!
Would we need a new tune from Manic, or is Map C meant for this type of set up?
Old Oct 3, 2014 | 10:30 PM
  #111
Systemlord's Avatar
Systemlord
How are the cylinder numbered? Is it #1-#4 from right to left? Sorry for the newbie question.
Old Oct 4, 2014 | 08:43 AM
  #112
Tommy Liveoak's Avatar
Tommy Liveoak
How do I get the stock studs off?
I looked up the directions online and and there are no words only pics and my kit did not come with any....
I got everything else off but the top of stock studs look like reverse torques? I am sure I am missing something any help is appreciated.
Old Oct 4, 2014 | 08:49 AM
  #113
SPRINTCARS's Avatar
SPRINTCARS
Just a thought
Old Oct 4, 2014 | 09:41 AM
  #114
cerenkov's Avatar
cerenkov
Originally Posted by Tommy Liveoak
How do I get the stock studs off? I looked up the directions online and and there are no words only pics and my kit did not come with any.... I got everything else off but the top of stock studs look like reverse torques? I am sure I am missing something any help is appreciated.
Use a star socket (found one at Lowe's). If you're careful you can use a 5 or 5.5 mm socket.
Old Oct 5, 2014 | 02:25 PM
  #115
mininewbnorthwest's Avatar
mininewbnorthwest
Sorta thinking the same thing, cute photos, shat instructions
Old Oct 5, 2014 | 03:18 PM
  #116
Tommy Liveoak
Yep got it done but real instructions would have helped alot..
Old Oct 9, 2014 | 06:05 PM
  #117
cerenkov's Avatar
cerenkov
My spacer is going to make more than 10 hp. Dyno numbers coming soon after i get the correct nozzles. Center 2 are mock up at the moment.
What sizes jets are you planning?
Old Oct 9, 2014 | 06:54 PM
  #118
vetsvette's Avatar
vetsvette
Moderator
Still waiting for someone else to try this with an AEM CAI. Not feeling too guinea piggish myself.
Old Oct 10, 2014 | 05:27 AM
  #119
Grizld700's Avatar
Grizld700
Me either. I feel like the thing is going to push up into the hood scoop unit.
Old Oct 10, 2014 | 05:44 AM
  #120
cerenkov's Avatar
cerenkov
I can't see how it would work with the AEM intake. The airbox is moved up and back so I'd imagine that the scoop part would not align correctly.
That being said, I've decided to keep mine and reinstall as soon as I can find a DOS intake....anyone have one that they want to sell?
Old Oct 10, 2014 | 12:46 PM
  #121
EuroTechsAZ
ready for installation , modified block for closer to equal length hoses
https://www.facebook.com/video.php?v...726057&fref=nf
Old Oct 10, 2014 | 08:47 PM
  #122
Systemlord's Avatar
Systemlord
Sweat, looks very promising and the engine will thank you it. It seems to flow very evenly between runners.
You think the spacer could be sliced half it thickness to a half and inch? For W/M only of course, some will have trouble fitting the full 1" inch spacer depending on what CAI they run.
Old Oct 13, 2014 | 10:07 AM
  #123
CravenSpeed's Avatar
CravenSpeed
Vendor
Making some other sizes could be a possibility. Since we could not possibly test fit with all possible intakes, we are looking to hear feedback on which do or don't require the hose spacer and if there are any that just will not work. If it turns out there are
Of course, I am happy to refund anyone who discovers that their intake is not compatible and cannot use their Koala because of it!
Old Oct 13, 2014 | 10:23 AM
  #124
vetsvette's Avatar
vetsvette
Moderator
Old Oct 13, 2014 | 10:33 AM
  #125
SPRINTCARS's Avatar
SPRINTCARS
Gotta some way to fasten that air box for the AEM systems. Can't wait til euro sends a pm about one for sale. It'll be bought and I'll figure out the air box later. Can't be that hard to make work if you have any kind of fab skills and ability and tools to do it.
IM IN A GROUP BUY IF IT COMES UP. if not, I'm still in. Screw it.
