R56 Need some exhaust advice
Old Mar 28, 2014 | 04:04 PM
jlips's Avatar
jlips
I have a '07 Cooper S and Was looking to buy a new cat-back exhaust soon. I've narrowed it down to the NM and the Borla. My question is, how hard are these to put in. I know the NM needs me to cut my stock pipes. What about the Borla? Anybody have any install instructions?
Old Mar 28, 2014 | 04:24 PM
Big Jim Swade's Avatar
Big Jim Swade
They should be pretty simple, but you will need to make a cut to your stock system. The easiest way to do this is with an air powered cut-off wheel. That will make the cleanest cut and you can keep it square. It will be difficult to try to do it with a hacksaw with the exhaust still on the car. You also might want to consider the factory JCW rear pieces.....
Old Mar 28, 2014 | 04:36 PM
cerenkov's Avatar
cerenkov
It's about the easiest thing that you can do. You will need to put the car on jack stands. If you don't have a cut off wheel then you and completely remove the whole exhaust from the downpipe back and then cut it with a hacksaw. If you do this make sure you pickup a new clamp for the downpipe connection.
When I installed my system it took about and hour or so.
Old Mar 28, 2014 | 11:25 PM
elsenordave's Avatar
elsenordave
I'm happy with my ARKDESIGN...free shipping to Hawaii was a bonus...looks great, sounds great:
I have since paired it with a WMW downpipe.
Old Mar 29, 2014 | 06:09 AM
Grizld700's Avatar
Grizld700
I ended up going with the DP-back NM system because I didn't want to cut the exhaust. The install was really easy. I installed the NM short shift adapter and box cover when I did mine so it took 45-60 min. Very straight forward. But as cerenkov said, you'll need a new clamp as well. V band clamp. You can order it online from ECS. Also as elsonordave said, paired with the WMW Catless DP, this thing sounds great.
Old Mar 29, 2014 | 08:41 PM
Lotus_'s Avatar
Lotus_
does ur exhaust sound whistle on 5k rpm??
any warning light pop up afterr u replace dp??
Old Mar 30, 2014 | 12:39 AM
elsenordave
Mine had a MIL light until my tune due to the cat removal...
Old Mar 30, 2014 | 09:37 AM
Grizld700's Avatar
Grizld700
NO, my exhaust system is the revised one. I had to wait a month and a lahf last year to get it. I've now had it on since late September last year and have never hear to 5k whistle. So as long as you buy new, I don't see a problem occurring.
As for the DP, yes. If you replace the DP with a high flow Cat or a Catless you will end up with a CEL. There are ways to trick the vehicle to think its ok by using spacers, but I wanted to get a tune as well, so I had it removed with my tune. There is also a device that tricks the ECU from Akrapovic, but I understand its not a perfect device.
Old Mar 31, 2014 | 12:06 AM
Melangell's Avatar
Melangell
Cat back gives NO performance update at all, just a noise maker. Go DP-back so when one day you decide to replace the DP, get tune etc you will have the whole package.
sevin
May 2, 2026 06:11 AM
xpunisherx
Nov 27, 2015 03:32 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
