R56 Who has pulled fenders?
Old Oct 30, 2013 | 01:11 PM
HorizonBLueN18's Avatar
HorizonBLueN18
So i know it's damn near impossible but i was wondering if anyone has tried to pull their fenders? I could really use about 1/4 inch more clearance up front and i know it's really hard to do as you have to keep the fenders aligned. Has anyone tried and has some words of wisdom? the front is what i really want pulled but the rear would be nice as well. Thanks for the info.
Old Oct 30, 2013 | 05:39 PM
MatthewMateo's Avatar
MatthewMateo
Well, if you insist on having your car appear and drive like you have broken suspension... You could just get drunk, heat up those fenders, and roll a baseball bat on it.
It's what all the MK4 tards do. You can do it too!
Old Oct 30, 2013 | 06:24 PM
MatthewMateo
Dude, why are you trying to roll your fenders. Just curious. I mean I know why you want to, but you drive a 2011 MCS. It holds one of the best residual values of any care on the market. All the bolt on modifications you've tossed on thus far can easily be removed and returned back to stock in a weekend, but you pulling you fenders can't really be undone.
Just food for thought.
Old Oct 30, 2013 | 06:29 PM
cerenkov's Avatar
cerenkov
I'd be concerned about not being able to do quality work. It might look like crap. Then you're screwed.
Old Oct 30, 2013 | 06:35 PM
Agbullet25's Avatar
Agbullet25
Maybe he likes the way HIS car looks and just wants to roll the fenders to make sure any possible rubbing is eliminated. He doesn't care what YOU think about HIS car, just cares about advice to make his car work better for him.
And to your other points, there are more advantages to rolling fender lips and fenders than simply slamming it to the ground like some ghetto lowrider. Race cars have rolled and stretched fenders in order to have wider wheels and meatier rubber on the wheels without having fenders get torn up from rubbing.
So how about you only provide some helpful advice to make sure HE can enjoy HIS car better versus YOU trying to tell HIM how to drive and build HIS car. Let's try that for a change.
Back on topic for the OP, I'm not quite sure how to go about doing it since the fender edges are plastic and would have to be removed to get to the actual metal fender. And I wouldn't guarantee that if the metal fender is rolled/stretched, the plastic trim will be able to snap back into place.
Old Oct 30, 2013 | 06:38 PM
HorizonBLueN18
These are my main concerns which is why i was looking for advice. I don't really want to do it if noone has any pointers on it not looking like crap.
Old Oct 30, 2013 | 06:44 PM
Motor On's Avatar
Motor On
Anyone thinking that certain behavior in earlier posts was acceptable, I would like to remind you of the following guideline.
RESPECT
When posting, both members and vendors must ALWAYS be respectful of fellow members and vendors. Personal attacks, trolling/baiting, deliberate antagonizing, and flaming will not be tolerated. If you feel you are being attacked, report the post or private message rather than replying or flaming back. However, do not use the report bad post feature to "cry wolf" when you are in fact the instigator of the demise of a discussion. Doing so will result in an infraction or strike.
Back to your regularly scheduled thread.
Old Oct 30, 2013 | 06:45 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
There are things you can trim back, and get some more clearance, but as far as stretching the sheet metal back to fit really wide wheels, and have your car slammed... Pretty much impossible without heavy modification in a body shop and a full respray, then you would need to have different arches made because the stock ones wont fit.
Old Oct 30, 2013 | 06:57 PM
danjreed's Avatar
danjreed
Did anyone ever offer a wide body kit?
Old Oct 30, 2013 | 07:00 PM
HorizonBLueN18
yea, i'm thinking i'm just s.o.l. as you can see in the pick. due to the offset of the wheel i just really need 1/4 inch more but i do agree. if i try to roll the metal and change the way the fender flows there is a good chance it won't look good. sigh... and i love my wheels and don't want to get another setup anytime soon. gotta brainstorm some more. I know it's petty and people thinking that it would be a lot of work to lower the car anouther 1/4 inch or so but it's my style and it's what i like.
Old Oct 30, 2013 | 07:26 PM
Agbullet25's Avatar
Agbullet25
Is it possible to attack it from a camber perspective with some camber plates instead of a bodywork angle? I'm not an expert on extremely lowered cars, but just throwing out an idea.
Old Oct 30, 2013 | 07:57 PM
HorizonBLueN18
I thought about that as an option but I got unlucky and have one of the minis that has axle bind when you lower the car to a certain point. I actually had to lower my car beyond this threshold. And as I'm unsure on how the geometry of what causes the axle bind besides the passenger axle being too long, I didn't know if adding camber would put the axle at a angle where it would bind again. But it is true. Even a small amount of camber would give me the clearance I need.
Old Oct 30, 2013 | 08:13 PM
KennyR's Avatar
KennyR
Nice to see the moderators handle inappropriate posters. Maybe Matthew can find another forum to rant on...
Old Oct 31, 2013 | 02:40 AM
danigurrl's Avatar
danigurrl
My fenders are sorta rolled. We didn't have enough clearance in the rears and they were rubbing on metal. We took the plastic covers off and took a rubber mallet and bangs them up a bit. It worked! The plastic fender covers popped right back on and no one can tell the difference. The only downside is the my tires have rubbed away a good portion of my plastic fenders. I have very slight negative camber...just enough to fit my tires.
I'm not a big "stance" person, but I had to do a little tire stretching and cambering to fit my sexy wheels.
I'm not sure if that helps or not...I didn't read through this whole thread when I saw the bashing. I support anyone's style, even if I don't argee with it.
Old Oct 31, 2013 | 05:00 AM
Mcameron's Avatar
Mcameron
while it may not be the easiest (or cheapest) solution for most people.....i know if i wanted larger fenders, i would most likely try to make them myself.
i think i would first go out and buy a completely seperate set of fender trim( that way if i screw up, i still have the stock trim to put back on), and i would use that as a 'base'.....i would then build it up with foam, cutting and shaping it until i got the look i wanted, then i would seal the foam and use it as a mold and make the fenders out of fiberglass.
once the glassed pieces are set up, youd have to trim them to size, prep them with bondo, primer, ect. then figure out a way to attach them (ide most likely rivet them on), then you paint to match your car.
a lot of work, but i think that would be the least invasive and 'safest' option.
i think if you do it right, you can get away with doing only the wheel arches, and leaving the side skirts alone.
Old Oct 31, 2013 | 06:15 AM
v10climber's Avatar
v10climber
You really gotta get some front camber in there. You should be able to dial in a little and just work your way up till you get axle bind then back off a little. Then take it to an alignment shop to get your toe fixed. Have you PMd Rally? He's awfully low in his clubbie. Have you tried swapping axles to see if that fixes the binding problem? Have you trimmed the front plastic flares yet? They have a small lip on them that could be ground off to give you some more clearance. What's the full specs on the wheel/tire setup? Offset? I'm surprised you're not hitting anything inside like the top of the wheel well. Are you only rubbing on the fender?
Old Oct 31, 2013 | 08:58 AM
DICKS GARAGE R53
Rally's Clubby has been totaled for over a year... Probably gone through the crusher by now. :(
Old Oct 31, 2013 | 10:37 AM
cranker625's Avatar
cranker625
Really? Our totalled cars up north just get auctioned, then rebuilt and sold with salvage title...We're Canadians, we're too apologetic to crush cars. We'd be saying sorry to every car we crush.
Old Feb 22, 2015 | 04:50 PM
Brandon_Schulze's Avatar
Brandon_Schulze
Did someone page me??
Last edited by -=gRaY rAvEn=-; Feb 22, 2015 at 06:03 PM. Reason: Offensive Remark deleted - PM to Brandon.
elverado
Jan 18, 2022 02:51 AM
asmasm
Aug 18, 2016 09:34 PM
cozy1356
Sep 24, 2015 05:37 AM
ekerley
Sep 23, 2015 04:48 PM
jcb-memphis
Sep 16, 2015 05:45 PM
