R56 Help with engine noise!
Old Jun 11, 2013 | 12:18 PM
kumankan's Avatar
kumankan
Hi everyone! I got my Mini back from the dealer a couple of days ago. They told me the Mini Cooper dealer they sent the car to found the engine noise to be normal. What do you guys think? Does it sound normal?
Thanks!
Old Jun 11, 2013 | 01:29 PM
bimpower's Avatar
bimpower
That is not normal. Need to check timing chain slack.
Old Jun 11, 2013 | 02:04 PM
CarlosDMotor's Avatar
CarlosDMotor
Timing chain problems. Tell them to measure it
Old Jun 12, 2013 | 05:26 AM
kumankan's Avatar
kumankan
Thank you all for your replies! I'll call the dealer and let the service department know. One more question, is it ok to drive it like that? What can be the worse that can happen? Should I be gentle with it or can I drive it normally ( spirited driver)?
Old Jun 12, 2013 | 08:28 AM
CarlosDMotor
Let it warm up before you drive it hard
Old Jun 12, 2013 | 09:38 AM
kumankan's Avatar
kumankan
Absolutely, always do! Thanks!
Old Jun 12, 2013 | 11:21 AM
ocluck's Avatar
ocluck
did you check your oil level, too?
Old Jun 12, 2013 | 12:12 PM
kumankan's Avatar
kumankan
Oil level is right in the middle between low and max level.
Old Jun 12, 2013 | 01:35 PM
mslatter's Avatar
mslatter
Maybe they think the timing chain problem is so common that it's now considered "normal."
Old Jun 12, 2013 | 03:14 PM
Namotuman's Avatar
Namotuman
I'm assuming the concern is over the clackity-clack noise.....the crickety chirp-chirp-chirp sound is normal on the R56, no? Well, maybe more like tickety-tick sound, not chirp......
Old Jun 12, 2013 | 03:39 PM
jlee924's Avatar
jlee924
How many miles on your MINI?
Could be a noise from the timing chain being stretched. The clacking sounds more like combination of a noisy friction wheel and water pump wheel/the water pump itself.
Old Jun 12, 2013 | 04:32 PM
kumankan's Avatar
kumankan
The car has 45700 miles.
Old Jun 13, 2013 | 08:37 AM
kumankan's Avatar
kumankan
Well, I called the dealer today and explained the issue. They told me that I should contact the Mini dealer they had sent the car to for repair. Short story, I bought my mini from herbconnolly Hyundai. Car went back twice for check engine light within the last 5 weeks ( own the car for about 6 weeks now). Turned out being a turbo vacuum line issue. Both times the car was sent to the Boston mini dealer. So I'll setup an appointment and keep you posted.
Melvinyip
Apr 17, 2020 09:28 AM
woodstudio
Mar 15, 2020 08:28 AM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
