R56 Check engine light problem
Old May 1, 2013 | 05:18 PM
flakoR56's Avatar
flakoR56
Ok guys so yesrtuday I was driving normal to my friends house on the high way and out of no where I see the red temperature light on so I pull out on the next exit. When I get out of the car I see the coolant hose spilling all the coolant. I got a zip tie and drove to the next autos hop and got it fix. New coolant 50/50 and a clamp for the hose that some how got off. But now I get this check engine light on all the time I have a ultragauge obd2 reader and I clear the check engine light of but when I turn the car off and I turn it on later on it comes back up any help?
Old May 1, 2013 | 05:43 PM
Braminator's Avatar
Braminator
Whats the code?
Old May 1, 2013 | 06:04 PM
flakoR56's Avatar
flakoR56
Whats the code?
Sorry I forgot to mention I get no code.... Idk what it is I check for pending or last recorded codes and nothing
Old May 1, 2013 | 06:17 PM
Braminator's Avatar
Braminator
You might try unplugging the battery for a few minutes and see if it clears.
Old May 1, 2013 | 06:32 PM
flakoR56's Avatar
flakoR56
Ok ill do that right now lets see if it clears
Old May 1, 2013 | 06:42 PM
flakoR56's Avatar
flakoR56
And nothing still comes up scanned for codes and nothing
Old May 1, 2013 | 06:49 PM
Braminator's Avatar
Braminator
So you can clear the light and it comes back on, but throws no codes? Did coolant get on any of the electrical connectors anywhere?
Old May 1, 2013 | 07:57 PM
flakoR56's Avatar
flakoR56
no sir the coolant hose the one that on the bottom did not touch anything or did i spilled some around :( and yea i can clear it off when i turn the car on then it wont show up ever again till i turn off the car then start it up again
Old May 2, 2013 | 01:21 PM
flakoR56's Avatar
flakoR56
any help :(
Old May 2, 2013 | 03:42 PM
Braminator's Avatar
Braminator
Have you lost any power or notice any other issues?
Old May 2, 2013 | 03:59 PM
flakoR56's Avatar
flakoR56
Nope the car runs perfectly fine no lost of power or nothing
Old May 2, 2013 | 04:07 PM
DneprDave's Avatar
DneprDave
You probably have an air bubble in the system, if you lost much coolant. There is a cooling system bleeder screw on the top of the engine, right hand side as you are looking at the engine from the front of the car.
Dave
Old May 2, 2013 | 04:16 PM
flakoR56's Avatar
flakoR56
Dave
And what do I do just unscrew it?
Old May 2, 2013 | 04:43 PM
DneprDave's Avatar
DneprDave
You just loosen it, don't take it out and bleed the air out, when it stops sputtering air, tighten it back up.
Dave
Old May 2, 2013 | 04:48 PM
flakoR56's Avatar
flakoR56
Dave
Ok Dave thanks a lot
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
