R56 TRS HID retorfit
Old Mar 24, 2013 | 08:56 PM
Scott Kuo's Avatar
Scott Kuo
TRS HID retorfit
Damn.....I love the color and cutoff
Attached Thumbnails TRS HID retorfit-329.jpg   TRS HID retorfit-333.jpg   TRS HID retorfit-345.jpg
Old Mar 25, 2013 | 04:45 AM
yetti96's Avatar
yetti96
H1 or D2S? I love mine.
Old Mar 25, 2013 | 05:27 PM
Scott Kuo's Avatar
Scott Kuo
that's H1
Old Mar 26, 2013 | 05:47 AM
yetti96's Avatar
yetti96
Cool, the look like they sit back in there pretty nice. I had to remove quite a bit to get my D2S in there.
Old Mar 26, 2013 | 09:27 AM
OreoPanda's Avatar
OreoPanda
How hard are these to put in?
Old Mar 26, 2013 | 10:44 AM
yetti96's Avatar
yetti96
If you are semi decent with a dremel it's not bad. I just took it slowly and did it in a day that I work off work and just hung out in the driveway with my table and my dogs.
Old Mar 27, 2013 | 09:35 AM
smokeysevin's Avatar
smokeysevin
They look nice, what did you secure the projectors to the housing with?
Sean
Old Mar 27, 2013 | 11:17 AM
Carmichael's Avatar
Carmichael
Nice, I take it you went with their Mini H1 Bi-Xenon projectors?
I used the OE projectors for my R53 retrofit. Cutoff isn't quite as crisp, but since I'm running a Morimoto 55 watt ballast, it's quite bright with a 5k bulb.
I have to say, though, my passenger side ballast starts to flicker occasionally on start-up. Goes away after a few seconds, but it is annoying. Of course, this happens after the TRS warranty expires ...
Old Mar 27, 2013 | 12:08 PM
Scott Kuo's Avatar
Scott Kuo
My both side of lights got flicker too. TRS told me it's because the ground wires did not secure correctly.
I will try to switch some ground wires to see if that fix flickering.
Old Mar 27, 2013 | 12:15 PM
Scott Kuo's Avatar
Scott Kuo
Sean
I was able to secure the projectors using J-B SteelStik.
Attached Thumbnails TRS HID retorfit-photo-1-.jpg   TRS HID retorfit-photo.jpg   TRS HID retorfit-photo-2-.jpg
Old Mar 27, 2013 | 12:18 PM
Scott Kuo's Avatar
Scott Kuo
it took me almost 7 hours to completed everything. it could be faster if you have a nice cutting drill. I used a $20 ''ebay'' drill and it did slow down my work tho.
Old Mar 27, 2013 | 08:37 PM
ajstefanacci's Avatar
ajstefanacci
I did this retrofit in a friends focus and their kits are awesome. Yours look great too.
http://forums.focaljet.com/mk-i-exte...-retrofit.html
Old Mar 28, 2013 | 08:00 AM
yetti96's Avatar
yetti96
I secured mine with the locking nut on the back of the projector. I also dremeled less than the OP did.
Here is before more cutting...
The first time I did these I used a smaller shroud, I have a larger one that covers more now.
Old Mar 28, 2013 | 08:48 AM
Carmichael's Avatar
Carmichael
Did you end up having to use their CAN-bus harness too? The connections on mine were a little loose, but a couple zip-ties fixed it. What bulbs are you running? I have the Morimoto 55 watt bulbs and one of them has already color-shifted a little.
The bad ground issue seems kinda plausible ... I can get mine to stop flickering by turning the steering wheel to cycle the electric power steering pump.
Old Mar 28, 2013 | 01:39 PM
Scott Kuo's Avatar
Scott Kuo
TRS told me there is no difference between 35W and 55W bulbs today.
Did CAN-bus harness fix your flickering issue?
Old Mar 28, 2013 | 01:44 PM
Scott Kuo's Avatar
Scott Kuo
Can you show us a picture of the locking nut on the back please?
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
brucenick
Sep 21, 2015 12:37 PM
tylewis
Sep 6, 2015 07:36 PM
