R56 is this bad spark plugs?
Old Nov 17, 2012 | 12:01 PM
yyj3869's Avatar
yyj3869
im having service now. im curious if its bad
Old Nov 17, 2012 | 01:26 PM
mslatter's Avatar
mslatter
How much mileage are on those puppies? They look ready for replacement to me.
http://www.hayabusa.org/forum/mainte...ence-pics.html
Old Nov 17, 2012 | 01:42 PM
Capt_bj's Avatar
Capt_bj
color wize I'd say you are fine. What you have is tan or what some would call 'biscut' and that means things are OK. You don't want oil or hard black carbon deposits.
So far as wear, well I don't see anything that scares me. Don't be confused by the look of the tip. On older plugs the tip is isually about 1/8 inch in diamter and if you saw the end as thin as this you'd know that plug had seen a very long life. But modern plugs, especially the iridium type used in the MINI come out of the box like that. This picture from MINIMANIA shows a typical GEN2 "S" plug
So I'd be happy with this plug, would check the gap ('cept I'm not even sure what is supposed to be cuz most come today "pre-set") & replace when over 50,000 miles
p.s. from MINIMANI: Cooper S - 15-20 Nm or 10.8-14.5 lb-ft. Recommended electrode gap: 0.8mm or .032"
Old Nov 17, 2012 | 02:38 PM
yyj3869's Avatar
yyj3869
its justa mini cooper 07model and hits 73k now.
Old Nov 17, 2012 | 02:39 PM
yyj3869's Avatar
yyj3869
I dont know which comments is right..
Old Nov 17, 2012 | 02:42 PM
submitaweasel's Avatar
submitaweasel
Plugs are cheap. If those are originals, I'd say replace them, at your mileage.
Old Nov 17, 2012 | 02:57 PM
yyj3869's Avatar
yyj3869
im having idle problem. Does it matter with spark plugs?
Old Nov 17, 2012 | 03:42 PM
submitaweasel
Could be any number of things. You could try plugs since theyre cheap. If that doesn't fix it...well post back with a video or something.
Old Nov 17, 2012 | 05:09 PM
Capt_bj's Avatar
Capt_bj
and just to confuse you more
if it is time to replace the plugs it is also time to replace the wires . . . and possibly the coil pack . . . .
yes, if the plugs have more than 50,000 miles on 'em I'd replace, and if I saw no improvement I'd move up the line .... wires ... then coil pack.
That's what I did on my 79 anyway . . . plugs, wires, rotor, cap, coil and points.
but as an indicator of 'engine performance' the color of the deposits on the plugs says you are running OK, and the plugs do not show unusual wear.....
nothing different here than my earlier post.
what sort of an idle problem?
Old Nov 17, 2012 | 09:01 PM
yyj3869's Avatar
yyj3869
accelerate about 1-5mpg and leave the pedal and rpm goes down to 500 with vibration. somtimes it seems like it going to stall.
Old Nov 23, 2012 | 11:59 AM
yyj3869's Avatar
yyj3869
i just changed spark plugs but idle still on....
Old Nov 23, 2012 | 12:34 PM
submitaweasel
What?
Old Nov 23, 2012 | 12:41 PM
yyj3869's Avatar
yyj3869
Even though i changed spark plugs, still have idle problems
Old Nov 23, 2012 | 12:42 PM
submitaweasel
Take a video of it?
Old Nov 30, 2012 | 02:52 PM
yyj3869's Avatar
yyj3869
https://www.youtube.com/watch?v=25iJ...e_gdata_player
Old Nov 30, 2012 | 03:35 PM
submitaweasel
What problem was in the video?
Old Nov 30, 2012 | 11:25 PM
yyj3869's Avatar
yyj3869
Problem Iv'e been having on my 07 justa. When driving in stop and go traffic, the rpm drops under 700, to about 500, and vibration will be felt throughout the car. Any other users get this?
To get it to happen, take your car into a parking lot, let off the brake and apply very little gas, to move less than 2 mph, then let off the gas and apply brakes. Do you see your rpm drop below 700?
here is the link. I know the video shows civic hybrid but this is exactly same situation I'm suffering.
Old Dec 1, 2012 | 03:16 AM
submitaweasel
I noticed that you've got an auto trans. (If the first video is yours) These do put more load on the engine than a mamual and if theres an issues with the trans that may be causing these issues. Its a shot in the dark but have you ever changed the fluid in the trans?
Old Dec 1, 2012 | 10:06 AM
yyj3869's Avatar
yyj3869
Yes first video was mine. its automatic and hits 74k now. last time i went to service shop and asked about transmission fluid but they said its lifetime for mini cooper. never changed fluid
Old Dec 1, 2012 | 01:41 PM
submitaweasel
The "lifetime fluid" is a sham. Do a quick search on here most recommend changing every 30k or so. Does it have any shifting issues? Transmission whine? If not that can probably be ruled out.
Old Dec 9, 2012 | 09:40 AM
yyj3869's Avatar
yyj3869
after replace the spark plugs, do i need to reset ecu?
Old Dec 9, 2012 | 12:37 PM
Rich.Wolfson's Avatar
Rich.Wolfson
No. Not necessary.
///Rich
Colt45Magnus
Aug 27, 2024 05:03 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
Filmy
Sep 7, 2015 08:27 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
