R56 Consensus on Oil Catch Can?
Old Sep 12, 2014 | 06:04 AM
  #51
67morris's Avatar
67morris
Saikou Michi dual can comes with proper 3/4 (19mm) inlets and outlets and he can also provide same size hose for pretty cheap. You would need four 3/4" nylon couplings (about $10 shipped from USPlastics). Splice your factory hoses and you are done
Old Sep 12, 2014 | 08:38 AM
  #52
ridinDirty's Avatar
ridinDirty
Such through a 1/2" straw for 10 sec then suck through a 3/4" straw for 10 sec. Which one will you get more from. Your engine is going to suck with the same amount of pressure but your going to get less with the smaller dia hose.
If you have a 2" hose and reduce to 1/2" and then back up to 2". You can only flow as much as the 1/2" section can flow. It's acting like an orffice plate
Old Sep 12, 2014 | 09:06 AM
  #53
Grizld700's Avatar
Grizld700
Thats all well and good, but the previous statement was about pressure drop not volume of air. I probably got stuck on the pressure point and didnt look at the overall picture. I would agree, you will flow more with a larger tube. However I still say you will have higher pressure with a smaller one. Like a garden hose. Make the hose smaller and it sprays farther due to high pressure.
Again, I think I got off point. Pressure in this case doesn't matter as much as having a large enough diameter hose for the gasses to pass through without too much obstruction.
Old Jun 28, 2020 | 01:19 AM
  #54
RoyBane's Avatar
RoyBane
3 way occ ?
Hei,
Does anyone excplain, why not use 3-way occ ? I know that 2x 2way occ is best solution, but yeah.... no room is the issued...
Old Jun 28, 2020 | 06:33 AM
  #55
Jason Cornelius's Avatar
Jason Cornelius
Originally Posted by RoyBane
Hei,
you can run the three port but you would need to block off one of the incoming ports. I’m running the block of plugs on the passenger side and OCC on the driver’s side with no issues.
Old Jun 28, 2020 | 02:42 PM
  #56
Seaswood's Avatar
Seaswood
I installed a BSH oil catch can along with a new valve cover a couple summers ago, this is a summer car at moment.
the BSH can does not have a drop of oil or anything in can? Have not driven a lot of miles but it has been driven.
i think what it needed was the valve cover not so sure about catch can?
installed as instructions.
Old Jun 29, 2020 | 04:25 AM
  #57
Jason Cornelius
I just bought my mini in November last year. So during the winter months I was collecting a ton, I was letting the car idle till up to temp. Then I read it was better to drive car up to temp, so I have been starting car and let idle till it drops, maybe 30 seconds, then drive up to temp, I don’t allow it to rev past 3k, once to temp let her rip. But anywho I’m not collecting as much now that it warmer. I don’t know if it’s the change of gas from winter to summer, but I’m using the same oil.
Old Jun 29, 2020 | 07:29 AM
  #58
cristo's Avatar
cristo
Alliance Member
I get a lot of water and some oil all winter
and just a little water and some oil all
summer with a BSH OCC on the driver side
and the passenger side blocked off.
Much more condensation is trapped in
cooler weather.
Rajapruk
Jul 15, 2014 03:41 PM
sharpstick
Oct 19, 2013 11:25 PM
SOCALGUY2007MCS
May 15, 2012 08:58 AM
Sullosar
Apr 20, 2010 05:06 PM
cnhoward
Aug 1, 2007 04:24 PM
