R56 High Pressure Fuel Pump - Install at home?
Old Nov 6, 2011 | 02:57 PM
baredm's Avatar
baredm
Is replacing the HPFP something a shade tree mechanic can to at home?
Old Nov 6, 2011 | 03:45 PM
bluefox280's Avatar
bluefox280
Sure, just need the fuel line removal tools, but otherwise its overall straight forward.
- Erik
Old Nov 6, 2011 | 04:18 PM
ballandchain's Avatar
ballandchain
- Erik
I would buy the Bentley manual before though......
Old Nov 6, 2011 | 08:54 PM
bluefox280's Avatar
bluefox280
With the Bentley, it is straight forward.
But that was assumed the OP had a reference to one.
- Erik
Old Nov 7, 2011 | 04:16 AM
yetti96's Avatar
yetti96
Isn't the HPFP covered by a 100k or so warranty?
Old Nov 7, 2011 | 04:26 AM
schatzy62's Avatar
schatzy62
The OP does not state whaty year car they have but yes it is covered for older years and then newer years one would think it is still under the normal warranty. Unless the car has more than 100K then I would think having it done for free would be the way to go.
Old Nov 7, 2011 | 08:10 AM
Porthos's Avatar
Porthos
Is it 100k or 120k? I thought it was 120k. Unless you are over that why? Just make the stealership do it.
Old Nov 7, 2011 | 08:32 AM
yetti96's Avatar
yetti96
I can only guess tons of mods...maybe.
Old Nov 7, 2011 | 04:02 PM
etalj's Avatar
etalj
He might not be from the states. The HPFP is not covered like it is in the states. I know that's the case down here in Aus. No 10yr warranty for us!
Old Nov 8, 2011 | 04:36 AM
schatzy62's Avatar
schatzy62
The letter I got from MINI about this states 100,000 miles.
or if you look at it another way it is twice the standard warranty
Old Jun 8, 2012 | 07:59 PM
Nubz's Avatar
Nubz
Any link to the extended warranty? Mini USA refusing to replace ours with only 57k miles on an '07?
Old Jun 8, 2012 | 08:28 PM
05r50's Avatar
05r50
Here is the letter.
It is 10 years, 120,000 miles on the N14 motor.
File Type: pdf
Old Jun 8, 2012 | 08:40 PM
Nubz's Avatar
Nubz
Thanks for the link. Sucks ours is the base. So frustrating cause the fuel pump temp sensor and water pump all went at 57k miles along with something to do with the airbag or server sensor.
09R56
Nov 16, 2022 10:49 AM
squawSkiBum
Oct 2, 2015 09:21 AM
kpl
Aug 11, 2015 04:52 AM
