R56 Check engine
Old Nov 1, 2011 | 04:45 PM
arkane333's Avatar
arkane333
Check engine
I have a P2477 fault code and a half full amber check engine light.
Does anyone know this code and will pulling the battery clear the light?
Old Nov 1, 2011 | 06:57 PM
etalj's Avatar
etalj
pulling the battery won't clear the light. Find someone with a scangauge or similar to clear the fault.
Google says that P2477 is Exhaust Gas Temp Circuit is erratic. Sounds like an O2 sensor.
That's a generic code, but I'll look it up when i get home in my Bentley manual
Old Nov 1, 2011 | 08:56 PM
arkane333's Avatar
arkane333
Thank you that will help alot I'm new to mini's but not turning wrenches and info on mini's in Kansas is rare.
Old Nov 2, 2011 | 06:32 AM
etalj's Avatar
etalj
I just checked my Bentley Manual, and it doesn't even have a P2477 code. Are you absolutely sure that it was P2477?
Even still, there is a generic code that I found on Google that says it's an Exhaust Gas Temperature Circuit Intermittent/Erratic. This interesting, as I don't believe that the R56 monitors Exhaust Gas Temperature (it sorta can in a roundabout way, via the cat temp sensor, but this isn't the same thing.
I would guess that your second O2 sensor is going south.
Basically your car's exhaust system has two O2 sensors, one immediately after the turbo, and the second one after the primary catalytic converter (the MCS has two cats). The first one is the most important, as it relays information to the ECU about whether the mixture is too lean or too rich. The second O2 sensor just makes sure that the catalytic converter is doing its job.
Old Nov 2, 2011 | 04:43 PM
arkane333's Avatar
arkane333
I guess i'll have to wait and see if the empty check engine light comes on again? My biggest problem now is the half full amber check engine dummy light an acutron scanner pulled the dreaded P115C code on earlier threads it's been figured as a MAF cleaning issue. I cleaned it and cleared the code but the light won't go off and the acutron says no codes found?
Old Nov 2, 2011 | 05:18 PM
etalj's Avatar
etalj
So you have a CEL and the scanner isnt picking anything up? Crikey.
Maybe have to find a BMW dealer and ask them to read it.
Old Nov 3, 2011 | 03:06 PM
arkane333's Avatar
arkane333
I hate to offload the car but i think i might just have to. This is annoying and plain odd to have ghost lights. I don't care to drive two and a half hours to have a dummy light figured out on an out of warranty car. :/
Old Nov 4, 2011 | 07:11 PM
etalj's Avatar
etalj
Take it to a BMW specialist. Someone who knows what they're doing. (Not a BMW dealer, 90% of them are ridiculous)
rob&JCW
Feb 13, 2023 07:03 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
