R56 DIY Brake job?
Old Oct 17, 2011 | 04:03 PM
Powashiftin's Avatar
Powashiftin
DIY Brake job?
Anyone know where I can find detailed instructions?
Old Oct 17, 2011 | 04:16 PM
Boosted_Mini's Avatar
Boosted_Mini
Its not very hard.
1. loosen lug nuts
2. jack up car
3. place jack stand
4. remove wheel
5. remove the two bolts on the back of the caliper to do just pads.
6. to do rotors remove two bolts that hold on the caliper and the two that hold on the pad carrier.
Its really not hard to do at all.. did mine.
Old Oct 17, 2011 | 04:58 PM
Porthos's Avatar
Porthos
^+1
Pretty easy job minus the brake bleed. I haven't done mine yet. Waiting till I get ss lines.
Old Oct 17, 2011 | 05:33 PM
Powashiftin
Thanks guys.. Looking for more info like what size sockets ill need etc.
Old Oct 17, 2011 | 05:48 PM
DneprDave's Avatar
DneprDave
The Bentley manual has all that stuff in it.
Dave
Powashiftin
I found this - http://r56mini.com/cooper/diydiscsandpads/
Any other ones?
Old Oct 17, 2011 | 05:55 PM
Boosted_Mini
I believe one bolt is a 13mm and the other one is a 17mm but its been awhile.
Old Oct 17, 2011 | 06:51 PM
Eddie07S's Avatar
Eddie07S
Originally Posted by Boosted_Mini
Its not very hard.
1. loosen lug nuts
2. jack up car
3. place jack stand
4. remove wheel
Skip step 5...just do step 6 for doing either the pads or rotors. It is much easier to undo the 2 bolts on the back and just lift everything off the rotor. Plus you don't have to chance getting dirt and/or water into the caliper slides. I have done this many times this way. OBTY, get a small bucket or the like to set the caliper on so you don't stretch the brake line. Also, to do the rotors you will need a Torx (#40?) wrench to take of the retaining screw.
This is for a 1st Gen. Some of the brake hardware is different but the process is the same. Take a look. Has alot of detail and pictures.
https://www.northamericanmotoring.co...beginners.html
wildwestrider
Sep 4, 2015 06:25 AM
Sep 2, 2015 09:05 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
thebordella
Aug 31, 2015 01:37 PM
shark715
Aug 30, 2015 07:01 PM
