R56 Yellow Engine Light on the Way Home From Dealer
Hmmm. I started a thread about getting the yellow check engine light while driving my brand new s home from the dealer. It was posted on July 1. I wonder where it went?
Anyway, I tightened the gas cap, and when I started it up to go to the dealer, the light was gone. The code was a general EVAP system problem, which could be a gas cap problem, or a problem with a solenoid, charcoal canister, or leaking hose connection. Time will tell. I had another vehicle that threw the EVAP code. It used to come and go for a month. Finally, the light stayed on all the time. Turned out to be a bad solenoid valve.
https://www.northamericanmotoring.co...om-dealer.html
Click on search --> advanced search. (Use the search at top right of page by yellow MINI not the this thread search)
Put your username in the username search box and click search now button.
wah la ...every post you ever made.........
Did you do exactly as I said and use the ADVANCED search and search by username?
Give a man a fish... feed him for a meal....
Show him how to fish.. feed him for a lifetime...
I guess I failed.
I must be losing it! I did a search for all posts by laneess in all forums before starting the second thread. The search didn't find anything. Now, when I did the search again, it showed my original thread, but it was in the JCW section.
Somebody help me here. Did anybody else see the original thread in the 'Coupe Talk' section of the forum?
That did not come from the Bible. It's an ancient Chinese proverb.
http://ezinearticles.com/?Lao-Tzu---...time&id=512280
You could ask the moderator move or combine the 2 threads if you want.
09R56
Nov 16, 2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
