R56 Ultra Gauge battery drain problems on 2008 MCS
Old Apr 13, 2011 | 11:57 AM
bossjh's Avatar
bossjh
Just installed a UG and it finds 49 gauges on my car. Things have gone smooth until the battery on my MCS ran down over night. I have tried the fixes suggested by UG to change the power on and power off settings as well as the restart time of 300 secs but still runs the battery down over night.
It has not been left in the menu mode which can cause the battery problems.
UG thinks it's a mini issue and may either drop support for UG on the Mini or try to re engineer fix beyond the stop gap measure shown on their support website.
Any body got suggestions on how to make this work short of returning the unit?
Old Apr 13, 2011 | 01:27 PM
schatzy62's Avatar
schatzy62
Make sure that the Main power line to the UG is not connected to a always on line. then it can not drain the battery.
Old Apr 13, 2011 | 01:46 PM
bossjh's Avatar
bossjh
Thanks. The UG is only connected to the OBDII port where it draws its power. Apparently, when it goes into a very low pwer mode when the engine is shut down it starts listening to the CAN bus after 300 seconds to come on stream when the MCS engine starts. If other MCS systems are still active then the UG starts scanning and draws power. Supposedly all the MCS systems become inactive after 80 seconds but that might not be the case. Its beginning to look like I need to somehow tap in and monitor the MCS electrical system draw after ignition off and without the UG connected......
Old Apr 13, 2011 | 02:00 PM
sooper_cooper's Avatar
sooper_cooper
Take a look at this thread: https://www.northamericanmotoring.co...e-install.html
There talking about that issue there as well. I hope it's a simple fix. I want a UG myself but I don't want the dead battery that comes along with it.
Old Apr 15, 2011 | 11:25 PM
5zero4's Avatar
5zero4
I have one and just unplug it before leaving the car for any longer than 2 hours. It seems to me the easiest way to fix the problem would be a relay that cuts the "always on" power to the OBDII port when the ignition is off. Are there any issues with cutting the OBDII power supply?
If you did this it would just have to scan whenever you start the car. No biggy, takes about 15 seconds.
I would return it, but I noticed a slight scratch on the screen, so at this point it's mine until the Iphone 5 comes out and I ditch my blackberry, at which point I will get the bluetooth OBDII adapter and run either Torque app or Rev app.
Old Apr 19, 2011 | 09:19 AM
bossjh's Avatar
bossjh
I've been talkign with UG support and they have requested I send back my UG for an upgrade. I did some testing for them on my 08MCS and we determined there is a bug in the UG. They understand the problem and say they will produce a fix but you have to send the UG back to them.
I will update status when I here about the UG fix and retest the UG on my 08MCS. BTW it seemd to turn on my start/stop enfine button light and most likely other systems as well. Mine drains over night.
I did use the UG for a while and really like the functionality and price so I am going work the problem with the UG support and engineering team.
More later......
Old Apr 19, 2011 | 10:48 AM
automan21's Avatar
automan21
I have a scanguage not a ultraguage but it should just turn off a few seconds after ignition is off. So yeah u got a dud, maybe the new one they give you will have a few more features.
Old Apr 20, 2011 | 07:44 AM
bossjh's Avatar
bossjh
BTW the UG does not drain the battery itself. It quietly (1/4 watt) sits on the CAN bus via the OBDII port and listens for the engine to start. The 300 second delay in the UG manual tries to give all the mini systems time to power down then it goes back on line listening for engine start. My 08MCs powers down in approx. 90 seconds but when the UG comes back on line listening the mini systems start up again. Wish I had a wiring diagram to better understand which system come back to life when the UG starts listening. These other mini systems detects UG listening and remain on with a much higher battery drain. The guys at UG think they have a way to trick the other Mini systems and stop the drain. Mini systems have a history of remaining on once and a while a causing a battery drain.
I think our friends at UG will fix this for all us Mini guys.
Old Apr 20, 2011 | 08:00 AM
strobeyprobey's Avatar
strobeyprobey
This wouldn't be limited to just MINI either, BMW's E60, E89 and E90 series will respond the same way. It is terminal 30g that the UG keeps waking back up that powers up many systems.
Energy diagnosis: Terminal control
For more information; see general functional description of the power supply:
Function selection -> Complete vehicle -> Body -> Power supply
Brief description
The power supply for the consumer units is delivered via various terminals. The terminal control is distributed across various control units:
•Terminal 30: Continuous +
Terminal 30 is routed from the battery terminal via the safety battery terminal to the front distribution box. As soon as the battery is connected to the terminals, terminal 30 is live.
Control units supplied by terminal 30:
CAS
Car Access System
DME/DDE
Digital Engine Electronics /Digital Diesel Electronics
DWA
Anti-theft alarm system (in the FZD)
EPS
electromechanical power steering
FRM
Footwell module
JBE
Junction Box Electronics
•Terminal 30g: Switched continuous +
Terminal 30g is controlled by the CAS. When the vehicle is wakened by an operation of the user, terminal 30g is switched on. Terminal 30g is switched off automatically after a codable after-run time (e.g. 30 minutes).
As in the case of terminal 15, the CAS activates a relay in the distribution box across a semiconductor switch.
Control units supplied by terminal 30g:
AMP
Amplifiers
CDC
CD changer
CID
Central Information Display
CON
Controller
CVM
Convertible top module
DAB/IBOC
Digital tuner / digital tuner US
DSC
Dynamic Stability Control
EGS
Electronic gearbox control
IHKA
Integrated automatic heating and air conditioning system
IHKS
Integrated heating-air conditioner control
IHR
Integrated heater control
RAD
Radio
RAD2
Radio 2
TPM
Tyre Pressure Monitor
RLS
Rain / driving light sensor
SDARS
Satellite tuner
SHD
Slide/tilt sunroof
SZL
steering column switch cluster
ULF-SBX
ULF-SBX-H
Interface box
Interface box High
VM
Video module
•Terminal 30g-f: Cutoff in the event of faults
Terminal 30g-f is a terminal 30 that is only switched off if faults are detected. The JBE controls terminal 30g-f via a bistable relay in the distribution box. The bistable relay can be switched off and on. As a rule, the bi-stable relay is always switched on.
The relay terminal 30g-f is only fitted with High equipment, e.g. when the Car Communication Computer (CCC) was ordered.
Control units supplied by terminal 30g-f:
AHM
Trailer Module
CA
Comfort Access
CCC
KOMBI
Instrument cluster
•Terminal 15:
The CAS controls terminal 15 depending on actuation of the start-stop button (with remote control inserted or identification sensor in the slot).
Terminal 15 is activated in the CAS via semiconductor switches. A relay in the distribution box is activated via the output of a semiconductor switch.
Control units supplied by terminal 15:
PDC Park Distance Control
DSC sensor
•Terminal R:
The CAS controls terminal R.
Here is the wiring diagram, however it is not entirely complete.
http://www.bmw-planet.com/diagrams/r.../r56/index.htm
Old Apr 20, 2011 | 09:50 AM
Minidrivr's Avatar
Minidrivr
Fes-Auto sells a switched OBDII plug. Wouldn't be as convenient as having it turn on/off with the car but it might be one solution.
http://www.fes-auto.com/products_det...p?productid=26
Old Sep 16, 2011 | 12:14 PM
rederik's Avatar
rederik
I have a late build 09 S and I just installed the Ultra Gauge EM, it has the metric & other extra gauges. It now has a boost gauge and can display 8 parameters on screen.
I've known about the batt drain issue but for the price of just a code reader, i took a chance. was planning on just unplugging it at the end of the day, just to be safe. i didn't remove it after 3 hours and the car starts (no deat batt, whew!).
However, if it is left plugged in and i start the car, i get a symbol on the tach. MINI on a lift, nothing else on the dash lights or the OBC. no codes on the Ultra Gauge either. The car drives fine, no problems otherwise. tried it a few times and same thing.
For now, i have to make sure to plug it in only after ignition on or starting the car. I'll somehow have to fashion a switch to power it on/off at pin 16 (12V of OBD), the OBD port on the car is too low to hook up a switched OBD port and the Gauge.
Old Nov 3, 2011 | 11:55 AM
selder's Avatar
selder
Is anyone running an UltraGuage on a 2012? Is battery drain still an issue?
Old Nov 3, 2011 | 12:58 PM
bossjh's Avatar
bossjh
Don't know about 2012 but UG still has a problem with Mini's. On their website they now say not compatible with Mini's. I've been waiting for 9 months for the fix. Just about ready to move over to Scan Gauge which supposedly does not have any problems.
Old Nov 3, 2011 | 02:04 PM
selder's Avatar
selder
Thanks for the update, thats a shame.
Old Nov 3, 2011 | 05:52 PM
Slave to Felines's Avatar
Slave to Felines
SG does not (so far, several weeks) have any problems with draining the battery.
Old Mar 11, 2012 | 09:27 PM
rederik's Avatar
rederik
I've been using the ultra gauge EM for about 3 months now. It stays plugged in to the obd port but it's not powered constantly. I disabled the gauge's pin 16(12v), and spliced it to the cigarette lighter. It now comes on & off with ignition on.
Only thing is, trip & fuel counters are wrong since it can't shut down properly. Every ignition off is like unplugging it without waiting for it to shut down, since the cigarette lighter is off as soon as you press the start/stop button.
Mainly use it as a boost gauge and coolant temp, cheap and easy
Old Jan 29, 2013 | 02:57 PM
uconnhuskiesfans's Avatar
uconnhuskiesfans
release 1.2 solved the dead battery issues
Old Jan 29, 2013 | 04:22 PM
selder's Avatar
selder
SUPER news!!!! I'm on my way to their website!!!
Old Jan 31, 2013 | 03:34 PM
uconnhuskiesfans
Bought one myself too, I just can't deal without a coolant temp gauge
silence2-38554
98
Sep 21, 2016 02:52 PM
triple5soul
21
Jul 29, 2016 04:27 AM
dyeLucky
Sep 11, 2015 10:41 AM
jeremy_reyes94
Aug 12, 2015 10:56 AM
dyeLucky
Aug 7, 2015 07:10 AM
