R56 stock turbo psi
Old Feb 19, 2010 | 07:38 PM
08cooperSblack's Avatar
08cooperSblack
stock turbo psi
anyone know how much boost a stock turbo from a MCS puts out?
Old Feb 19, 2010 | 09:49 PM
KevinC's Avatar
KevinC
.8 bar, or approx 11.6 psi.
Old Feb 20, 2010 | 08:20 AM
08cooperSblack
cool thanks
Old Feb 20, 2010 | 09:29 PM
eR1c's Avatar
eR1c
it also appears that the turbo kicks in stronger in certain gears ..i.e. I think from 2nd to 3rd gear is more boost than 1st to 2nd.
(that's what I've noticed on my boost guage).
Old Feb 20, 2010 | 09:45 PM
08cooperSblack
def i can feel the diffrence from 2nd to 3rd
Old Feb 20, 2010 | 10:41 PM
Ottoman_FD3S's Avatar
Ottoman_FD3S
it depends on teh year of ur car and what software version is has
07's with early software had the most boost
ask me how i know? the dealer updated my car without me asking
and now it's a dog :(
Old Feb 21, 2010 | 06:43 AM
KevinC's Avatar
KevinC
I've seen nothing documented about a difference based on what gear you're in. You're probably feeling the overboost function, which allows brief periods of extended boost when you stand on the throttle.
Old Feb 21, 2010 | 09:23 AM
Zo3o6's Avatar
Zo3o6
Hey all, just "FYI" on forced induction engines.
Look at it like: The engine is an air pump... air in / air out, the more air moving through the engine - the more power the engine makes. "Boost" is a measurement of air that the engine cannot "Process", hence the amount of air (pressure) that is "backed up" on the intake side of the engine.
The gearing in the drivetrain in the lower gears allows for the engine to race through the RPM range to redline and processing the maximum amount of air -thus - all the air that the turbo is feeding the engine in that short time frame being processed - less back up of air in the intake = less boost but same amount of air.
As you get to the higher gears - the RPM at full throttle climbs slowly... so the SAME VOLUME OF AIR (i'm simplifying) that was going through the engine in the lower gears cannot pass through the engine in the higher gears = a backup of air going into the engine = boost. So the more "LOAD" you put on the engine (which is equal to putting so much strain on the engine that it cannot advance in RPM at full throttle) = the more boost you make. less load in the lower gears = less boost. The turbo is working correctly the whole time.
Sorry so long winded!
Old Feb 21, 2010 | 09:40 AM
UAL_Kingpin's Avatar
UAL_Kingpin
On a side note, there is no talk on the forums about people doing a boost leak test. Along with a boost leak test, I would change all the pressure pipe clamps from the factory screw clamps to t-bolt clamps.
Old Mar 1, 2010 | 12:36 AM
Ottoman_FD3S
just to update this thread
I went and dynoed my car today.. pulling the boost info from the OBD port and logging it on the dyno
it was a flat 12psi all the way.. no spikes or drops at all
I NEED MORE BOOST :(
Dec 5, 2016 06:31 PM
jwmolmen
Sep 22, 2015 10:00 AM
PEterChoqu
Aug 26, 2015 08:33 AM
rckrzy1
Aug 11, 2015 06:06 PM
