R56 space saver tire for 09 MCS?
Old Oct 14, 2009 | 03:15 PM
emans's Avatar
emans
I'm trying to find one that works and not too expensive. Anyone have any ideas on where to find this? It's for an 09 MCS. thanks!
Old Oct 14, 2009 | 07:25 PM
dpcompt's Avatar
dpcompt
i bought a mini-saver spare from mini-mania. it only fits on the back. but when jacking your mini, both front and rear tires are lifted off the ground.
don c.
Old Oct 14, 2009 | 09:14 PM
Robin Casady's Avatar
Robin Casady
I'm not aware of a space-saving tire that will fit over the front brakes on an MCS. Even the MC 15" wheels wont fit.
Old Oct 15, 2009 | 04:21 PM
Tallman's Avatar
Tallman
Front tire flat
As I understand it, Robin, ....during a front tire blowout - you jack up your mini from the side, raising front and back. You would then place good rear tire on the front. The spare tire, goes on the back.
A bit of a hassle, I realize. All due to larger front braking system.
After switching away from RunFlats, you could also pack a can of Fix-a-flat instead of a spare tire. Just a thought.
Old Oct 15, 2009 | 05:45 PM
Robin Casady
Yes, that would be a hassle. When raising the front jack point, the rear will lift a little off the ground if you are on a flat area, there isn't much weight loaded in the rear, and you jack the front way up. Might be just as easy to do the rear first, then the front. Or, carry a 16" wheel.
I carry a sealant/compressor, and a Dynaplug kit.
Old Oct 15, 2009 | 07:33 PM
wayne290's Avatar
wayne290
Would a spacer work for putting the doughnut on the front?
Old Oct 15, 2009 | 08:02 PM
moe-jiller's Avatar
moe-jiller
Careful with that Fix-a-flat, Slime, et al stuff. There is forum traffic on NAM about those injected products messing up the Tire Pressure Monitor sensor and sending unit.
Old Oct 17, 2009 | 10:10 AM
inimini2007's Avatar
inimini2007
Not worried...R56 MCS built prior to 1 Sep 07 don't have the current TPMS setup.
Old Oct 17, 2009 | 10:12 AM
inimini2007
Some MINI owners have used the older Chevy Cobalt, Honda Civic Donuts.
Old Oct 17, 2009 | 10:31 AM
mattsenpai's Avatar
mattsenpai
YOU'RE NOT SUPPOSED TO put a spare tire on the front wheels of ANY front wheel drive vehicle!!!!
(brake size is not the reason either)
risk damaging your differential, stressful on the drive train, and handling greatly affected
woodstudio
Mar 15, 2020 08:28 AM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 04:15 PM
