R56 HOw do I take the inside trunk cover off in a 2008 cooper s?
Old May 31, 2009 | 02:49 PM
slickdaddy's Avatar
slickdaddy
I am trying to install a bar on the trunk of my 2008 cooper s. It will be used to pull down with to shut the trunk. How do I take the inside trunk lid cover off? I see two star head screws but it seems to be fastened around the perimeter. There are also two rubber wedges near the top that I took out and can't tell if there is some sort of latch in the hole or not. Any help would be appreciated as I am tired of pulling down on the paint to shut the trunk. Thanks to all. This forum has saved me so much time and $$. Keep up the good advice...
Old May 31, 2009 | 04:58 PM
Tygo's Avatar
Tygo
are you trying to drill through the trunk so that you can have a handle installed on the exterior to pull down on from the outside?
Old May 31, 2009 | 05:54 PM
rkw's Avatar
rkw
Besides the 2 screws, simply pull/pry the panel off from 8 attachment clips.
Attached Thumbnails HOw do I take the inside trunk cover off in a 2008 cooper s?-reartrim.gif
Old May 31, 2009 | 06:14 PM
Oxybluecoop's Avatar
Oxybluecoop
That panel is on there good.It will take a good amount of force to pop out those clips.
Old May 31, 2009 | 10:18 PM
Tygo's Avatar
Tygo
ok I know its your car and you can do what you want with it, but you drilling through your trunk and putting on a handle will look better than finger prints on your hatch?? seriously? You must have found the most amazing handle ever to make that possible. Can't you just keep 1 white cotton glove in your car if you're that obsessed with not having finger prints on the hatch? It would save money and avoid having your car look like a piece of luggage.
Old Jun 1, 2009 | 12:02 PM
RJKimbell's Avatar
RJKimbell
I use the Rectangular Latch to pull down the Boot Door. With a good bit of force it closes and locks with out much problem.
Old Jun 1, 2009 | 12:10 PM
OPC's Avatar
OPC
RATTUS Deserticus
I also loop a couple of fingers through the latch to pull the boot lower then I place my hand on the license plate to close the rest of the way. I don't even get dirty fingers.
Old Jun 1, 2009 | 01:50 PM
MakoBimmer's Avatar
MakoBimmer
I personally use the handle on either side of the hatch inside and then finish closing by pushing on the license plate....I never touch the paint with this method. Just a thought....
Old Jun 1, 2009 | 02:47 PM
number84's Avatar
number84
aren't there already 2 places to pull down on from the inside? i usually never have to touch the outside to close the hatch? am i missing something here?
mishanja
Jun 22, 2016 09:59 AM
MacenVA
Aug 14, 2015 05:25 AM
ludedude
Aug 10, 2015 07:16 PM
Aug 7, 2015 05:56 AM
