R56 Oil drain plug washer
I bought OEM oil filters for my car and they came with crush washers. When I changed the oil for the first time I noticed there was no crush washer on the car so added the one that came with the filter. Now, after doing the first oil change after the dealer service, I saw the dealer removed the crush washer.
Looks like this was a question with the 1st gen MINIs: https://www.northamericanmotoring.co...ug-washer.html
So, is a crush washer needed?
Knowing that I had read somewhere else that it was stuck on the oil pan when someone else had changed it, I got a flat screwdriver and voila..there it was! It was just pushed on so hard it was almost as if it were part of the oil pan. So your dealer may have found TWO when they changed it!
Tony
i had that question too when i did my first change... the cross section of it looks like a 6 or a 9 however you look at it but it seems like both the little 'tail' piece and and the actual roundness of it both crush to seal flat... i just put the more rounded side towards the pan lol
07-16-2020 12:54 PM
08-19-2015 12:51 PM
08-19-2015 08:27 AM
