R56 First Dyno
Old Jun 9, 2008 | 06:22 PM
fernflex's Avatar
fernflex
First Dyno
10k miles 2007 R56 Cooper S with Alta Intake and Alta Turbo Inlet Hose.
180.30whp
205.35 max torque
Run Conditions 93.29 F
30.28 in-HG
Humidity 28%
Tomorrow I will go to a different dyno because I didn't like this one. I am installing the new Invidia 2.5 exhaust thanks to jscspeed.com and I want to be sure of the before and after.
Old Jun 13, 2008 | 08:49 PM
old81's Avatar
old81
M6
Did you get your second base run?
I would love to know what you see on the dyno with then R56 Invidia.
Old Jun 13, 2008 | 09:06 PM
luckyduck's Avatar
luckyduck
Are you doing two different runs on two different dynos or are you going to start all over at the new dyno?
Old Jun 14, 2008 | 01:10 AM
fernflex's Avatar
fernflex
I didnt have time to go to the other dyno but this week I will go to the same one with the new Invidia exhaust to see what happens!
Old Jun 15, 2008 | 09:48 PM
luckyduck's Avatar
luckyduck
Okay, I thought you were doing a Before on one dyno and the After on another dyno. I was gonna say. . . .
Old Jun 16, 2008 | 06:30 AM
AmericanIdiot's Avatar
AmericanIdiot
are those corrected numbers SAE or STD?
Old Jun 16, 2008 | 06:35 AM
fernflex's Avatar
fernflex
I don't know, I have to check that!
How can I know?
Old Jun 16, 2008 | 06:47 AM
AmericanIdiot
It will say it somewhere on the print. SAE are the ones you want. Those #s sound right. I remember dyno #s on a supercharged mini in the 160+ rwhp. Was it a dynojet machine?
Old Jun 16, 2008 | 07:22 PM
fernflex's Avatar
fernflex
What is the difference between SAE and STD???
Old Jun 16, 2008 | 08:30 PM
Ryephile's Avatar
Ryephile
If you're going to do a before and after, you should do them on the same dyno and the same method of operation [same gear, atmospheric correction formula, etc.] Your baseline numbers are very good compared to a DynoJet or DynaPack, what brand of dyno was it on? Why are you displeased with the numbers?
Old Jun 16, 2008 | 08:50 PM
fernflex's Avatar
fernflex
It says Dynojet!!!
Im trying to go tomorrow to the same one...
But Americanidiot ask me about the Std and the Sar and I want to know the difference.
In what gear should I run the car 3rd or 4th???
Old Jun 26, 2008 | 03:23 PM
old81's Avatar
old81
M6
Hi,
Any updates on your dyno runs with the complete setup.
Thanks,
Don
Old Jun 26, 2008 | 03:36 PM
fernflex's Avatar
fernflex
I am wainting for temperature here in PR to drop a bit because its been hot.
Old Jun 26, 2008 | 03:52 PM
old81's Avatar
old81
M6
Great, keep us informed. Are you trying to get back to a 90 degree day?
Old Jun 26, 2008 | 06:11 PM
Ryephile's Avatar
Ryephile
Originally Posted by fernflex
It says Dynojet!!!
Sorry, I don't see any picture attached. Thanks for telling me anyway.
You want to run the car in 4th gear to get the most accurate torque data.
Old Jul 14, 2008 | 09:01 PM
Mach V Dan's Avatar
Mach V Dan
I run most six-speed cars in fifth gear. Fourth will be a pretty short run, and may not load a turbo car enough to make maximum boost and torque.
Here's some details on a typical Dynojet chart:
This is a plot of an R53 GP along with a 2007 Cooper S.
First, let's look at the maximum values. Simple, right? Not so fast! First of all, those are the maximum numbers pictured ON THE GRAPH, not the max the car made on that dyno run. If were were to scale the X axis to only read to 4000 rpm, the maximums would be different. If we use a different correction factor or smoothing number, the maximums will change. And if the tach lead were to lose track of the RPM for a bit, we might miss the torque during part of the dyno run. (More on that later.)
Note at the top right, it says CF: SAE. That means SAE correction, which is a standard formula that tries to normalize runs across weather (temp and barometric pressure) conditions. (SAE = Society of Automotive Engineers, and they have set a standard for this.) Other choices are STD, DIN, and some weirder ones. Honestly, SAE is the only factor anyone that I know uses. The actual amount corrected will be on the "Run notes," which are usually printed out either on your dyno chart or on the following page. It'll be a percentage by which the numbers are scaled up for down. It might be, say, 99% because on this particular day it was a little cooler than the "ideal" day, so to normalize against the warmer ideal day, the power (as shown on the graph) is slightly reduced.
There's also a note saying Smoothing: 5. The Dynojet software allows you to set that between 1 and 5. I always use 5, because I want to see overall trends, not teeny little spikes. (Set it on 1 and you'll see very, very small perturbations in the power delivery. Basically noise.) But smaller smoothering numbers will mean higher actualy maximums in most cases, because the spikes will be slightly higher.
Also note that the scale for HP and Torque are the same on each side. This is NOT locked in, and it can be confusing if the two axes are scaled differently. I try to always make sure they're scaled the same.
Note too that if the scales ARE the same, the HP and Torque lines will ALWAYS cross at 5252 rpm. It's the law.
Seriously, that's because one is derived directly from the other. In this case, the Dynojet directly measures the acceleration of a heavy drum to determine horsepower. it divides the power number by engine RPM to figure out torque. If you leave the tach pickup off the car, you get no torque number. (Although if you knew the gear ratios and/or the engine speed at a given road speed, you could calculate it...)
--Dan
Mach V
NYMADMINI
Dec 14, 2016 02:33 PM
slash695
Apr 26, 2016 06:27 AM
USA-RET
Nov 9, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
