R56 No Temperature Guage
Old Apr 5, 2008 | 04:41 PM
redfearn's Avatar
redfearn
The 2nd Generation Minis seem to have adopted the BMW "feature" and left off a temperature gauge - we just traded in a 2004 MCS for a 2008 MCS and the only gauge is for the gas tank. There are warning lights (Yellow/Red) that would alert you to overheating - but I like to watch the temperature gauge when starting up in the morning to know when the car is fully warmed up and I can start driving more aggressively. Seems like a silly omission as it can't cost that much for a gauge. (After the new BMW 3-Series came out a couple of years ago, I got a test drive, and had to point out to the salesman that there was no temp gauge - he went hunting through the computer trying to find one!) At least we have an oil dipstick to use - the BMWs have removed those too. The aftermarket gauges are expensive to install. Does this bother anyone else?
Old Apr 5, 2008 | 05:39 PM
Minidrivr's Avatar
Minidrivr
Yeah it bothers a lot of us. I put a Scangauge II in since it required no modification to the car. There are some threads on gauges for the R56, but none are from the factory.
Old Apr 5, 2008 | 06:57 PM
ColdFyre's Avatar
ColdFyre
I thought with this being 2008 and all and technology where it is, that this was a myth.
At least is was back in 1994 with my Camero.... According to all the mechanics I've been too.
Perhaps BMW tech isn't as far along as I thought
Old Apr 5, 2008 | 07:00 PM
Robin Casady's Avatar
Robin Casady
I also went for the ScanGaugeII. It gives you a digital readout of your choice of various data from the OBC. I usually run it on coolant temp (usually 222-225F), manifold absolute pressure, mpg, and mph. I wish it had oil pressure and temp, but they don't seem to be in the OBC.
Easy to install -- plugs into the OBDII port.
Old Apr 5, 2008 | 07:07 PM
ScottRiqui's Avatar
ScottRiqui
Actually, the oil temperature gauge would be a better indication of when the engine's fully warmed up.
Oh, I forgot - you don't have one of those either...
(grinning, ducking and running).
Old Apr 5, 2008 | 07:11 PM
emtrey's Avatar
emtrey
I, too, have always used the oil temp as my indicator of a car ready to be driven hard. Wish we had one. This car needs one, big time.
Old Apr 5, 2008 | 07:19 PM
k6rtm's Avatar
k6rtm
Another vote for ScanGaugeII -- coolant temp, MAP, intake air temp, mph.
But after driving with it for a while, I think you can get an idea why there isn't a coolant temp gauge -- coolant temp starts out low, climbs rapidly into the operating range, and stays there. So looking at it, when things are good, it just confirms that things are good. And when things go bad, it's going to confirm that as well!
cheers--
Old Apr 5, 2008 | 07:51 PM
MDLMini's Avatar
MDLMini
Being at work... where exactly is the OBDII port and how does it connect to the ScanGuageII? Where are you mounting the ScanGuageII?
Thanks,
Mark
Old Apr 5, 2008 | 10:01 PM
k6rtm's Avatar
k6rtm
Search posts on NAM for ScanGaugeII and you'll see a number of mounting options. A lot of folks put the display in the middle cubby ahead of the shifter.
The connector is by your left knee as you're sitting in the car, a small capped connector on the lower dash trim by the door. It's easy to route the cable around from there.
cheers--
Old Apr 5, 2008 | 10:29 PM
Robin Casady
Thanks,
Mark
The OBDII port is under the dash just to the left of the steering column. You remove the cover and plug the ScanGaugeII cable into it. I mounted mine on top of the dash with Velcro. That way I can remove it when I take the car in for service.
Old Apr 6, 2008 | 12:06 AM
Minidrivr's Avatar
Minidrivr
There are a couple pictures of the OBDII port and the Scangauge II in my gallery. I use coolant temp, voltage, intake temp, and mpg on mine most of the time.
imncrxtc
Jan 19, 2018 03:16 PM
asmasm
Aug 18, 2016 09:34 PM
gnhovis
Sep 28, 2015 04:07 AM
rt808
Sep 25, 2015 01:59 PM
tylewis
Sep 6, 2015 01:07 PM
