R56 Did iPhone update screw up my Bluetooth connection?
Has anyone had problems with the iphone update (1/16/08) causing conflicts with their blue tooth operation on the '08 MCS? Trying to figure out if it's a MINI issue or an iphone issue. The MINI blue tooth system/iphone worked fine before the update....but both the phone and the car are new.
I have a MCS '08 with Comfort Access/ blue tooth mobile phone prep.
iPhone update did screw up bluetooth operation in pretty much all cases (it seems). Does it cutoff right in the middle of a call etc?
Some say, the only way to fix it (until a new firmware release comes out) is to save all your information and then do a Restore to Factory Settings... then reload and re-pair your bluetooth. That seems like a lot of a pain to me... so I havent done it yet.
That's helpful. It would be worth it to me do go though the reinstating the phone, etc. If anyone else has had this experience, it would be helpful to know! Thanks.
Did you try un-pairing and then re-pairing the phone?
There is a known issue with Apple about 1.1.3 not working with some BT devices that the phone previously worked with. I have seen a few people commenting on this, however mine works just fine with the R56 BT kit.
Did resetting the firmware on the phone work?
R50 is the 2002-2006 Cooper
R52 is the 2002-2008 Convertible
R53 is the 2002-2006 Cooper S
R55 is the MINI Clubman
R56 is the 2007+ Cooper and Cooper S
R57 is the 2009+ Convertible
R60 is the MINI Crossman
Lex2008
How to
47
Jun 15, 2022 06:18 AM
COOPT UP
Sep 11, 2015 04:59 AM
NHcountryman
Sep 6, 2015 11:01 PM
