R56 Drought
Old Oct 18, 2007 | 08:08 AM
Phil K's Avatar
Phil K
Drought
My area of Virginia is currently experiencing mandatory water use restrictions; no watering the lawn and no traditional car washing. So would it be best to use a detailing spray or is there a better interim technique?
Old Oct 18, 2007 | 08:17 AM
glangford's Avatar
glangford
See if you can find a touchless drive through car wash. Some car washes may not have restrictions. I wouldn't use detailing spray unless I had washed the car of loose dirt and impediments. Wiping off a detailing spray w/o washing is a quick step to swirl marks.
I live in North Alabama and we are in what the USDA describes as an 'exceptional' drought, about the worst area of the country. On the plus side, as I still have my old CR-V, My new MC has yet to have been driven in rain since it arrived in April, of course, its only rained about 5 times since then, which for this area is indeed historic drought.
Old Oct 18, 2007 | 08:22 AM
unixgal's Avatar
unixgal
Twisty Road Lover
This thread should really be in the Detailing 101 forum.
Lots of answers there.
You wouldn't even be allowed to use two buckets of water???? Car washing doesn't have to involve having a hose running incessantly. Check out Detailing 101.
Old Oct 18, 2007 | 08:23 AM
Yucca Patrol's Avatar
Yucca Patrol
We haven't been allowed to wash our cars since June. I take the cars to a touchless wash when I can but have generally had to neglect them this summer.
Sad, so sad. . .
Old Oct 18, 2007 | 08:25 AM
netsatwork's Avatar
netsatwork
Here's a good solution. Used to be recommended a lot on the detailing forums like autopia a couple of years ago. I use it in the winter so I can wash in the garage.
http://www.campingworld.com/browse/p...D=1545:src=FPC
beowulf777's Avatar
beowulf777
Find a hand wash detail shop and take your own wash mitts.
Old Oct 18, 2007 | 08:28 AM
jakay11's Avatar
jakay11
+1 BTDT in previous years
msh441's Avatar
msh441
Griott's Garage has a terrific product called Speed Shine that might tide you over for the time being.
Old Oct 18, 2007 | 12:26 PM
Phil K's Avatar
Phil K
Thanks to all of you for the solutions.
Phil
Old Oct 18, 2007 | 01:27 PM
R56 Ed's Avatar
R56 Ed
Phil-
Is there any way to capture the water from your clothes washer when it is emptying from the rinse cycle? Most washers have a hose that just inserts into a drain in the wall, and that hose is often attached with a garden hose-type fitting. I'm wondering if you could pipe that outflow into buckets and re-use that water to loosen the crud on your car. Don't see how anybody could get mad at you for not conserving water since you're recycling it!
When I was building my house, I moved my washer and dryer into a detached garage (so I could still use them), and always directed the output from the wash to a useful location in the yard instead of just sending it down the sewer. The yard never looked better, although you might want to be careful about what kind of soap you used
Hope this helps. Can't have a dirty MINI
Old Oct 18, 2007 | 02:59 PM
surfblue's Avatar
surfblue
alternative to washing
California Car Duster and Speed Shine from Griot's garage. I'm no tree hugger but it's a lot easier than washing it all the time. We've been on a water alert almost rationing all spring summer fall. Works fine, less work, no water, end of story.
When I first got the car I washed it and put on Detailer's Paradise EPIC synthetic wax. Car sparkles, I have more time to drive.
Yeah, this belongs in the detailing forum.
Old Oct 18, 2007 | 04:26 PM
ladisney's Avatar
ladisney
Hey guys, come to Iowa. We're in the middle of the monsoons. Just leave your car outside with some soap on it and the wind and rain will wash it right up.
Old Oct 19, 2007 | 12:07 PM
CooperB's Avatar
CooperB
When I first read this I was thinking to myself this guy and lost his mind... but by the end of your post I thought "What a great idea!".
Question now: Will the soap used to wash your clothing strip wax?
I'm actully considering do this as we are under a total outdoor watering ban. My washer/dryer/mud room is next to my garage so it would be very easy to setup a 50 gallon drum in the garage to capture this water. Taking it a step further... maybe I could fit the drum with a back flow sensor which only allowed water to the drum if there was available space! When full the water would go down it's normal drain. Almost a set it and forget it approach.
Old Oct 19, 2007 | 12:42 PM
Phil K's Avatar
Phil K
Originally Posted by hypnohealer
Phil-
What a unique idea. Not sure if I can make it happen though. I'll check when I get home.
Old Oct 19, 2007 | 12:58 PM
Duffer's Avatar
Duffer
Pardon my ignorance, but what is wrong with brushless car washes?
Old Oct 19, 2007 | 01:07 PM
R56 Ed's Avatar
R56 Ed
First, Yes, I HAVE lost my mind I do miss it from time to time
To capture large amounts of the water from your clothes RINSE cycle (not the wash cycle) will take a bit of work on your part, and some ingenuity.
To get all MacGuyver about it, you'd start with a "Y" valve somewhere close to your washer so that could choose to route the used water either to the sewer line as it is now (suggest this for the soapy cycle) and then after that cycle was done, switch to your storage container for the rinse water. I don't think I'd like to use dirty wash water on my MINI
For storage, we use a device called a "rain barrel". Designed to catch rain from downspouts and save it for watering the yard during droughts, of all things. No reason you wouldn't use something similar. And these have hose fittings at the bottom to make it easy to attach a garden hose.
I'm guessing that most washers use about 5 gallons of water for each cycle, and if you only captured the rinse water, a 50 gallon barrel would give you 10 loads of laundry. More barrels, more storage.
Anyway, I hope this helps. And that you get a good laugh out of it
BTW, +1 on the California Duster after your car is decrudified.
Old Oct 19, 2007 | 01:21 PM
R56 Ed's Avatar
R56 Ed
Nothing at all What I'm suggesting is an envionmentally sound way to be able to wash our MINIs more frequently during water restiction conditions, for free, using water that would otherwise have been sent through the sewage treatment system needlessly, without having to leave the driveway. I'm actually a big fan of brushless car washes, and plan to use one this winter when it's too cold to wash Dr. P by hand
Old Oct 19, 2007 | 01:24 PM
Duffer's Avatar
Duffer
I think the one in my town recycles the water, but I don't know if they all do.
Have you had any damage done to your car by the brushless car wash?
Old Oct 19, 2007 | 01:40 PM
R56 Ed's Avatar
R56 Ed
'Have you had any damage done to your car by the brushless car wash?'
Only some very minor scratches to the clear coat. I have seen a few cars bumped when the folks couldn't keep up with the number of cars on the conveyor.
Ours also recycles SOME of the water, and that's great. I suspect that's the norm now. They told me they use the recycled rinse water as the wash water for the next cars going through. Maybe not perfect, but it's sure better than it was a decade ago. And it's great to let somebody else to all the work
Old Oct 19, 2007 | 01:43 PM
Duffer's Avatar
Duffer
Amen, Brother!
Old Oct 19, 2007 | 03:23 PM
gokartride's Avatar
gokartride
Truth be told it would behoove all of us to explore ways to wash our cars 1) w/o sacrificing quality while 2) using water wisely. Many parts of the country are in and out of watering restrictions and it doesn't hurt to have a workable backup plan. That said, I think many MINI owners take a more engaged, thoughtful, and intentional approach to car washing so you're probably well on the road to doing this anyway.
Old Oct 19, 2007 | 05:27 PM
PGT's Avatar
PGT
I just got some QEW....going to try it this weekend. NoVA restrictions stink....watching the landscapers dump water from the hydrant while my lawn whithers away :(
MGS131
R57 :: Cabrio Talk (2009+)
Mar 30, 2015 06:26 AM
trico
Detailing 101
42
Sep 25, 2008 10:08 PM
89AKurt
Off-Topic :: Autos
16
Mar 21, 2007 03:20 PM
spec35
Jul 13, 2005 10:11 AM
