R56 just installed DIY clear bra
Old Oct 13, 2007 | 03:02 PM
kimguroo's Avatar
kimguroo
I got cheap clear bra kit from ebay and installed today.
actually, I ordered hood, front bumper and mirror but only installed hood and half of the front bumper.
The Hood was really easy to install. Only took about 20 min.
the front bumper was kind of disaster. it does not stick to bumper well
and hard to get rid of the bubble. spent about one hour and stopped.
I might try to install another half of front bumper tomorrow.
I only spent $35 shipped so I don't care if clear bra goes wrong
Attached Thumbnails just installed DIY clear bra-front.jpg   just installed DIY clear bra-side.jpg   just installed DIY clear bra-bubble.jpg
Old Oct 13, 2007 | 03:03 PM
ghosthound's Avatar
ghosthound
wow, 35 shipped? i saw some on ebay that were around 140 for 3m material.
Old Oct 13, 2007 | 03:04 PM
kimguroo's Avatar
kimguroo
another pictures
Attached Thumbnails just installed DIY clear bra-side2.jpg   just installed DIY clear bra-last.jpg
Old Oct 13, 2007 | 03:06 PM
kimguroo's Avatar
kimguroo
it was not 3M. don't know what kind of material.
Old Oct 13, 2007 | 03:09 PM
ScottRiqui's Avatar
ScottRiqui
Wow - looking at the edges, the film looks pretty thick - did the directions/packaging mention the thickness?
Other than that, it looks good. If you're having adhesion problems on the bumper, try using a spray bottle with a water/isopropyl alcohol mixture in it. When you get the film where you want it, lift up part of the film and spray the water/alcohol in there, then lay the film back down and squeegee it out. The water/alcohol solution counteracts the water/soap solution that you use when positioning the film, so the film will stick in place.
As for the bubbles, some of those will actually go away with time, because the film is slightly air-permeable. If the surface underneath was clean, and you squeegeed it well, I wouldn't worry about the bubbles that are left. Just rub down the film with a soft cloth every day for the next few days to ensure that the film adheres to the paint as the bubbles collapse.
Old Oct 13, 2007 | 03:18 PM
kimguroo's Avatar
kimguroo
did not say anything about the thickness but there was directions mention about water/isopropyl alcohol mixture. where can I get isopropyl alcohol?
Old Oct 13, 2007 | 03:44 PM
ScottRiqui's Avatar
ScottRiqui
You can get it at the grocery store or any drug store. Most places carry 70% isopropyl alcohol solution, and that's what I mix 50-50 with distilled water to put in my sprayer. If for some reason you can only find 100% isopropyl alcohol, you can still use it, but I'd dilute one part alcohol with two parts water in that case.
Old Oct 13, 2007 | 06:19 PM
user 7082082's Avatar
user 7082082
That truly looks really thick. I am going to order this and try it out. You can not go wrong with that price.
Old Oct 13, 2007 | 06:42 PM
Lyme's Avatar
Lyme
who was the ebay vendor
Old Oct 13, 2007 | 07:19 PM
kimguroo's Avatar
kimguroo
nctintman
Old Oct 14, 2007 | 01:28 AM
user 7082082
I just got a full kit from these guys.
http://cgi.ebay.com/ebaymotors/Mini-...QQcmdZViewItem
Old Oct 14, 2007 | 11:06 AM
kimguroo's Avatar
kimguroo
what do you mean by you got a full kit? did you order it or receive it?
I also tried to order it from them but they did not have pre-cut mini bras last week. Now, I will finish a half of front bumper bra.
Old Oct 14, 2007 | 01:35 PM
kimguroo's Avatar
kimguroo
finally, Finished.
there was a little problem with fog light area and bottom of the bumper.
the pre-cut does not really fit so I have to cut and modified a little.
I could install red spot in the picture but my hair drier (more than 10 years old) was broken so I just cut it and did not installed it.
the hood was easy to install but I won't recommend the bumper.
Hope it will last long
Attached Thumbnails just installed DIY clear bra-imgp0001.jpg   just installed DIY clear bra-imgp0002.jpg   just installed DIY clear bra-imgp0003.jpg
Old Oct 14, 2007 | 02:31 PM
ghosthound's Avatar
ghosthound
hmm... i wonder how well that stuff holds up... i was considering getting the 3m material but that kit is 140 for the whole front end kit...
Old Oct 14, 2007 | 06:55 PM
dirkinoff's Avatar
dirkinoff
I purchased mine off of E-Bay also, I agree the lower bumper around the foglamps was a real pain and so was the hood scoop area, I just kept heating and stretching and adding water and in came out great! You really have to be in the right mindset to start because it is going to use every bit of patence you have . All in all I think it was well worth it. I could not part with 600.00 dollars for the dealer to do it, Yes I am that cheap!
Yours looks great I think.
Old Oct 14, 2007 | 07:00 PM
user 7082082
I put the order through. Its a pre-cut kit for the mini. Hood , bumper , and mirrors.
Old Oct 14, 2007 | 07:25 PM
kimguroo's Avatar
kimguroo
actually, my seller on ebay sent inside of side mirrors' clear bra.
I've never had any problem with inside of side mirrors before so I did not install it. good luck with installation.
Old Oct 14, 2007 | 07:35 PM
kimguroo's Avatar
kimguroo
I was run out of my patient, when I installed very bottom part of the front bumper. also my 10 years old hair drier was just broken, right before installing red spot area in the picture.
I don't know how long this bra will last.
by the way, when did you install yours? any problem yet?
just curious.
Old Oct 15, 2007 | 12:36 AM
user 7082082
Thank you , I will let you guys know how it goes.
Old Oct 15, 2007 | 01:34 PM
rockridge's Avatar
rockridge
I installed the 3M Aeroguard product a couple weeks back. I was successful at installing the hood, and upper bumper. I gave up trying to install the film on the lower bumper, as the area around the headlights would not fit right, and kept falling off. I gave up before I was forced to kill something.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ludedude
Aug 10, 2015 07:16 PM
bctf1
Aug 6, 2015 12:55 PM
