R56 Water temperature with scanguage II
I was literally wondering the same thing this morning.
I watched the range over the past month or so of use and my peak is 233 with average running right about 200.
It has been smokin' hot here in the South, so those might be a tad high...
ScanGauge II is pretty cool and handy...
Under the dash, to the left of the steering wheel, is the port for the OBC. Remove the cover, plug in the ScanGaugeII, and you are set. I've mounted mine on to of the dash with Velcro. I have a small block of rosewood that angles it upward so the light catches the face during the day. I find it hard to read if it is in the shadow of the roof when not illuminated.
It would be nice if it could be set to be illuminated all the time, rather than when the lights are on.
Is it that easy to plug in the more visually appealing pod-type gauges that can flank the tach?
Lordy, I'd love to know my water temp, voltage, and other vitals...
also check out Brockway Engineering. http://www.brockwayengineering.com/
Same concept, perhaps a bit cheaper, one or two additional options, ie shift light, 0 to 60 acceleration, exhaust temperature. And with R920, fits right below the toggle switches with no velcro!
The ScanGaugeII is compatible with the R56 and fairly inexpensive on ebay.
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
