R56 Water temperature with scanguage II
Old Aug 31, 2007 | 08:38 AM
Ex-Pat Brit's Avatar
Ex-Pat Brit
Now I have a means of seeing my temp (scanguage II), what should I be seeing??
Any other figures would also be appreciated
Old Aug 31, 2007 | 09:34 AM
Drewmon's Avatar
Drewmon
I was literally wondering the same thing this morning.
I watched the range over the past month or so of use and my peak is 233 with average running right about 200.
It has been smokin' hot here in the South, so those might be a tad high...
ScanGauge II is pretty cool and handy...
Old Aug 31, 2007 | 11:20 AM
daffodildeb's Avatar
daffodildeb
What is ScanGauge II?
Old Aug 31, 2007 | 11:28 AM
Tharkun's Avatar
Tharkun
A cool toy if you have some extra cash.
http://www.scangauge.com/
Old Aug 31, 2007 | 11:37 AM
Robin Casady's Avatar
Robin Casady
Mine typically runs 222 to 225 degrees F.
Old Aug 31, 2007 | 12:16 PM
Arnbut's Avatar
Arnbut
Interesting tool; how do you install it?
Old Aug 31, 2007 | 12:29 PM
Robin Casady
Under the dash, to the left of the steering wheel, is the port for the OBC. Remove the cover, plug in the ScanGaugeII, and you are set. I've mounted mine on to of the dash with Velcro. I have a small block of rosewood that angles it upward so the light catches the face during the day. I find it hard to read if it is in the shadow of the roof when not illuminated.
It would be nice if it could be set to be illuminated all the time, rather than when the lights are on.
Old Aug 31, 2007 | 12:40 PM
Arnbut's Avatar
Arnbut
All that data and that's it?
Is it that easy to plug in the more visually appealing pod-type gauges that can flank the tach?
Lordy, I'd love to know my water temp, voltage, and other vitals...
Old Aug 31, 2007 | 01:15 PM
Robin Casady
Which gauges, specifically? I know that some require tapping into the engine.
ScanGaugeII will give you voltate, boost (MAP), rpm, load, mpg, and a few things I've forgotten. It displays four at a time, you choose which ones. The major things it is missing are oil pressure and oil temp.
Old Sep 2, 2007 | 01:23 PM
Ex-Pat Brit
Getting 225 for water
Old Sep 2, 2007 | 01:48 PM
mistro's Avatar
mistro
also check out Brockway Engineering. http://www.brockwayengineering.com/
Same concept, perhaps a bit cheaper, one or two additional options, ie shift light, 0 to 60 acceleration, exhaust temperature. And with R920, fits right below the toggle switches with no velcro!
Old Sep 2, 2007 | 03:23 PM
familiarstranger's Avatar
familiarstranger
Do we (r56) need the DIN model of the R920?
Old Sep 3, 2007 | 01:27 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I could use one, what's the best deal anyone has been able to find on one.
Old Sep 3, 2007 | 10:04 AM
Ex-Pat Brit
Amazon is selling the scanguage for $159.99
Old Sep 3, 2007 | 12:23 PM
Robin Casady
The R920 is only compatible with 2002-2006 MINIs. They will have a new version sometime around the end of the year that will be compatible with the R56.
The ScanGaugeII is compatible with the R56 and fairly inexpensive on ebay.
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
