R56 Easy way to pop up the sunroof?
Old Aug 30, 2007 | 05:38 AM
narkose's Avatar
narkose
I am shopping around and I have niggling question about the MCS sunroof. I was unable to get the sunroof to automatically pop-up. Activating the button starts the process in motion and then I had to try and time it right to get the roof at pop-up. Most of the time I was too slow and the roof started opening by the time I released.
Am I just dumb or is this the design? My dealership sales manager admits to the same problem.
Old Aug 30, 2007 | 06:05 AM
Tharkun's Avatar
Tharkun
If you fully pull the switch toward you and then immediately release it, the sunroof will open to full tilt. The link below has sevral posts about it on pge #2.
https://www.northamericanmotoring.co...unroof+opening
Old Aug 30, 2007 | 07:49 AM
rattmobbins's Avatar
rattmobbins
What he said.
Even knowing that info before I got my car, it took me few tries to figure out what people were talking about before I was able to do it myself. You can also hold down the unlock button on the key fob, and it will roll down the windows and pop the sunroof.
Old Aug 30, 2007 | 07:56 AM
Loony2N's Avatar
Loony2N
It is a kind of counter-intuitive design. You have to push the switch past the resist point and then let go for the pop-up. If you stop at the resistance point, the roof stops when you do. If you don't let go after pushing into the resist point, it slides. It's one of those things that just take getting used to, like when to release the clutch.
Old Aug 30, 2007 | 08:31 AM
-Vampyre-'s Avatar
-Vampyre-
Man I try that everytime I get into the car and just can't get it to work...lol
Old Aug 30, 2007 | 08:34 AM
Loony2N's Avatar
Loony2N
Okay, just push the switch back (toward the rear) hard and, as soon as it goes all the way, let go.
Old Aug 30, 2007 | 01:39 PM
ahalibut's Avatar
ahalibut
I think I started to figure this out last night...
As you walk towards the car use your keyless entry and push the unlock button three times. On the third button push hold the button. This will open your side windows.
and/or
As you walk towards the car use your keyless entry and push the unlock button four times. On the fourth button push hold the button. This will "pop' your sunroof to the tilted position.
Old Aug 30, 2007 | 03:05 PM
rattmobbins
and/or
Dude, you just push and hold it once to do both.
Old Aug 30, 2007 | 05:25 PM
MotorMouth's Avatar
MotorMouth
great find about popping the SR from inside with one quick touch.
Opening from the outside with the fob - I always have the windows roll down first then the sunroof pops. Haven't been able to get the sunroof to pop first no matter what combo of pushes I do.
Old Aug 30, 2007 | 05:32 PM
Tharkun's Avatar
Tharkun
Nope....can't pop the sunroof first with the fob., but I can live with that.
Old Aug 30, 2007 | 05:55 PM
Coopaw's Avatar
Coopaw
I'm not 100% sure on this but I think the car has to be running for the pull back all the way and release for the pop up to work. When I've done it with just the fob in and not started it doesn't seem to work correctly.
Old Aug 30, 2007 | 06:20 PM
MotorMouth's Avatar
MotorMouth
The MINI doesn't have to be running but your key has to be in the accessory position (LoL) Key in, hit start button without pushing clutch or brake. Lights on dash come on then it'll work. Of course it works if you start the MINI too.
Old Aug 30, 2007 | 06:29 PM
Dubaian's Avatar
Dubaian
just push the sunroof button hard then release... it works just a click on the button!
ToyCar
Nov 19, 2023 05:20 AM
Lex2008
How to
47
Jun 15, 2022 06:18 AM
hockeydad51
Oct 9, 2015 01:51 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
