R56 Different type of noise from my MCS 6 speed has developed. Normal??
I have developed a noise in my MCS 6 speed. im at 3400 miles. i searched but could not find anybody else that describes the sound. when i am in ANY gear and get the engine revs up to 3000+ and let go of the gas and clutch i hear a noise from the trans. its sounds like a muffled busy rotating rumble grinding. its very hard to describe the sound. it can be quite noticable with the windows closed. funny thing was my 2004 had the same exact noise before i sold it. it sucks because when i give it any serious gas at all and then let go the car sounds like crap as it decelerates. so i have been driving it lighter and shipfting sooner to prevent the noise. anybody else heard of this or have this noise? is it normal? when you bring your MCS up past 3500RPMs and let go of the gas do you hear any noise at all from the transmission?
WAIT!!! on the ride home i realized it does happen with the clutch pressed. anybody have any ideas? it also gets worse the more the car is warmed up.
Flav,
I have the same noise on my 07MCS 6 spd. I originally though the noise was exhaust rumble coming from the muffler. It only happens when the car a has been running for a while. It also happens with or without the clutch engaged. It also only happens when I let off the gas.
Is this normal? I only have 1,240 miles, if you take it back to MINI let us know what they say. I'm willing to live with it as long as it is not damaging the car.
celljay
celljay
Hey guys, I checked on our mule (just turned 6000 miles from the trip to the Dragon and back). No noise. Sounds like a trip to the nearest service center is in order. Good luck! Report back to all of us to your findings.
Thanks again for posting. This helps ALL of us!
This has historically been linked to the DMF in both the R53 and the R56. There was an existing TSB for the R53. It looks like the problem has made it into the new model.
before visiting the service department, test drive a different 6 speed. That way you'll have an easier time describing the difference and you'll be ready for that, "I don't hear anything unusual".
P.S. My 6 speed does not in any way sound like what you describe.
I have read about grinding issues when shifting from third to second, but not the above mentioned issue.
What exactly did you experience to warrant a new tranny?
Thanks.
Exactly right, that wierd "rotating" noise upon deceleration.
I autocross and run the car hard and have not had any issues but the sound is noticeable, especially as the car gets up to operating temp.
It all started after they removed the tranny to replace the rear main seal, that had been leaking since delivery.
I have an appointment scheduled for this Friday. The sound really makes it's self noticed after the car is warmed up. I'll be taking it for a spirited drive before bringing it to the dealer.
YES!!! that exactly it!! its not there when the car is cold but the warmer it gets the louder the noise gets. and with the air con on its even louder. the car drives perfect so im not taking it to the dealer yet, anybody actually takes theirs in and see what this noise is. someone else described it as a rotating grinding noise (thats a great description)
Now that is something I would take to the service department.
