R55 R55 Key Fob Question
Old Aug 13, 2020 | 07:23 AM
StuSegal's Avatar
StuSegal
I bought a new Clubman in 2014, still have it, and am still using the original key fobs. Which do not have (easily) replaceable batteries, as you know.
What should I do?
  • Try to split open the fobs, de-solder the batteries, and replace them?
  • Spend hundreds to get new fobs from Mini?
  • Something else?
Any advice would be appreciated.
Old Aug 13, 2020 | 08:16 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If they still work, leave them alone. My understanding is the "key" slot in the dash has an inductive charger that keeps it charged up. So, as long as you keep using it, should be good.
Old Aug 13, 2020 | 11:24 AM
CakeEater's Avatar
CakeEater
Yea like Nik said, pop out the key to unlock your car if the fob is dead, then put it in to start the car and it should charge.
Old Aug 13, 2020 | 11:39 AM
StuSegal's Avatar
StuSegal
Agreed, but even rechargeable LI batteries have a limited life. The dealer tells me that the fobs usually die after 5-6 years, and I am not looking to replace both fobs for $300-ish… so I'm trying to be prepared with an an alternative (before they actually die).
Old Aug 13, 2020 | 11:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
My car was built in January 2012, and I'm still using the original fobs. I have had no indication that they are getting flaky.
Old Aug 13, 2020 | 12:43 PM
Jason Cornelius's Avatar
Jason Cornelius
Mine is an 09 and I’m still using both original keys. The one I don’t use that much, will lose a charge, but if I use it a couple of times it comes back to life.
Old Aug 13, 2020 | 12:59 PM
StuSegal's Avatar
StuSegal
Thank you, guys. I think I'll put away my soldering iron and stop worrying about it, for the time being.
Old Aug 18, 2021 | 08:20 AM
Buzzbcooper's Avatar
Buzzbcooper
Just say No!
[QUOTE=StuSegal;4549284]I bought a new Clubman in 2014, still have it, and am still using the original key fobs. Which do not have (easily) replaceable batteries, as you know.
What should I do?
  • Something else?
I own a 2009 Clubman (named Lazarus due to fact he's been brought back to life more than once!) Sounds like your 2014 has same type of key as Lazarus'.
marysmini77
May 25, 2017 05:40 PM
pmsummer
Aug 19, 2012 07:17 PM
that7guy
Oct 5, 2010 05:06 PM
tboner4me
Aug 12, 2008 11:09 AM
sbpwjm
Aug 12, 2006 07:05 AM
