R55 oil filter cap
Old 07-15-2019, 05:42 PM
jk6672's Avatar
jk6672
jk6672 is offline
oil filter cap
My son tried to impress me and change his oil himself. Now I need to fix it, lol. Ok, guys I ordered another oil filter cap and I'm ready to install it, but it's not as easy to get to as I thought it would be. I was trying to get an oil filter wrench around it to twist it off since he destroyed the socket head on the cap. I can't get in there to get any leverage, any ideas of how I'm going to get this off? I thought about drilling a hole through it vertically as a last resort and attempting to break it loose, but that my just break it into peices.
Old 07-16-2019, 06:37 AM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
might be able to get a grip with a strap wrench
https://www.harborfreight.com/2-pc-r...set-69373.html
better yet an 'oil filter strap wrench' where you could use a socket extension to work from the normal angle / top
https://www.ironpony.com/ipd/pi.asp/...r-Strap-Wrench
The following 2 users liked this post by Capt_bj:
Andy_S (07-16-2019), ECSTuning (07-16-2019)
Old 07-16-2019, 07:03 AM
jk6672's Avatar
jk6672
jk6672 is offline
I had an idea last night I may try today. Epoxy the socket to the striped cap and see what happens.
Old 07-16-2019, 07:09 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Some bent angle channel lock/water pump pliers https://www.ecstuning.com/b-knipex-p...nt8701250~knp/
or the strap might do it.
Old 07-16-2019, 07:35 AM
jk6672's Avatar
jk6672
jk6672 is offline
I wish is was that easy. I bought these from you hoping it would work, but it’s a no go.
https://www.ecstuning.com/b-schwaben.../006309sch01a/
Old 07-16-2019, 07:38 AM
Ah man, Not wide enough or just too tight to get in there? I was thinking to get the pliers on whats left on the hex end and twist. Once you get it loose you should be able to spin it off by hand.
Old 07-16-2019, 07:50 AM
jk6672's Avatar
jk6672
jk6672 is offline
I can clamp on it with the jaws at 90 degrees, but no room to twist. Definitely no leverage at 90. I bought the new cap and the stubby socket from you guys too. I’m really thinking some aero epoxy I have and the socket may be my best option at this point without destroying the cap.
Old 07-16-2019, 08:07 AM
Ok, thanks for the order, those jaws are good that you have for other cars that have spin ons and/or tractors and equipment. Yep, that might do it.
Getting that socket on all the way and using an extension at the correct angle will ensure you dont damage the cap in the future. I guess a good way for your son to learn the proper way.
https://www.northamericanmotoring.co...nge-oil-431461
Old 07-16-2019, 09:46 AM
jvanbrecht's Avatar
jvanbrecht
jvanbrecht is offline
Search for Reverse Threaded socket.. They make them for lugnuts that are stripped.. Might be able to find one in the right size...
Old 07-16-2019, 12:56 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
I think what you mean is an extractor socket and I was about to mention this ... it is what I've used to get off rounded GEN1 oil drain plugs (a common problem)
but you may have to search a bit to find a socket size large enuf ... the cap is 27mm isn't it?
This set and most I've seen max out at 3/4 inch - 19mm
here's a set that goes up to 27mm
Amazon Amazon
you could get ugly, drill and if it breaks well so long as you don't loose any pieces INTO the engine what's the loss? You have a new cap!
You could cut the top off and remove the element then 'destroy' the rest of the can ..... it's plastic so should break long before the metal it screws to.
Old 07-20-2019, 01:01 PM
jk6672's Avatar
jk6672
jk6672 is offline
Just to let you know, I did get it off. The aero epoxy worked, so now my son's cap permanently has a socket attached to it.
Andy_S (07-22-2019)
Old 07-22-2019, 07:18 AM
Thanks for the update.
trwxxa
11-23-2016 01:28 PM
jay80424
11-06-2014 07:03 AM
mckchr67
09-05-2013 07:26 PM
marucusu
Want to Buy - All Other Items (archive)
06-16-2008 02:38 PM
Quick Reply: R55 oil filter cap
