R50/53 Taking oil pressure from R53 oil filter housing cap?
Old Nov 3, 2014 | 10:58 AM
jay80424's Avatar
jay80424
Anyone done it?
I need to drill a hole in the oil filter cap to determine if the drainback valve is leaking, and figured I'd take oil pressure from there in the event it's not.
Old Nov 4, 2014 | 05:16 AM
jamez's Avatar
jamez
I thought I may have seen it once somewhere, but I can't find it right now.
I get what you're trying to do, but won't that interfere with removal/installation of the filter cap? The socket itself wouldn't sit right would it?
It's such a tricky install (with the pressure you have to apply when installing) I don't think I'd want any more difficulty added to it.
Old Nov 4, 2014 | 04:41 PM
ZippyNH's Avatar
ZippyNH
Frankly, I'd avoid doing it this way...
Sounds like a disaster in the making...
Be it from leaks, or the part failing when tourqued to tighten it or removing it...I cannot think how you could mount a sensor that would not get smashed or twisted during the install...
Guess if you have a spare cap to play with...could try it..be investigational... But not sure I would drive it...
Old Nov 4, 2014 | 05:47 PM
jay80424's Avatar
jay80424
Yea, I nixed that idea today and ordered a cravenspeed oil pressure adapter.
Now I just need to figure out how to determine if the drainback valve, or some other valve inside the housing is leaking.
I wish I had a part I could compare it to. It's quite difficult to check to see if the housing is draining back when if you open it to look it drains back!
Old Nov 6, 2014 | 05:04 AM
JABowders's Avatar
JABowders
Veteran: Army
Catching up, I remembered there is an adapter available for a few bucks that ties in to the sending unit. I was going to recommend this much more than drilling into the oil filter case.
The one I remember seeing I think was at Way Motor Works ...
http://www.waymotorworks.com/tapless-adapter.html
OK... more than a few bucks... but something like this I think would be much better.
Motor on!
Old Nov 6, 2014 | 07:03 AM
jamez's Avatar
jamez
hahahah... schrodinger's valve
TREX
Nov 2, 2019 07:31 PM
Aug 12, 2015 01:24 PM
clintmeister
Aug 12, 2015 11:11 AM
