R55 '09 Clubman's Driver Side Window?
I have a 2009 Mini Cooper Clubman and its driver side window won't close that last "little" bit. Is there a "likely" cause for this or do I need to bring it to the dealer which is 250 miles from me?
Thanks in advance...
Okay, solved the problem...
It is usually caused by a dead battery or battery change out.
Turn ignition to the "on" position with the door closed. Using the toggle switch, roll the window all the way down. After the window reaches the bottom of its travel, continue to hold the toggle switch down for an additional 3 seconds. Then, using the toggle switch, roll the window all the way up, and again, hold the button in the up position for 3 seconds.
mbu
Mar 1, 2016 04:09 PM
JFEINSTEIN
Oct 20, 2004 03:54 PM
amagnetta
Jun 25, 2003 02:29 PM
