R55 Mini throws oil over the valve cover.
Old Aug 31, 2016 | 09:59 AM
Wado1's Avatar
Wado1
It is my first post on the forum so I'd like to say hello.
I have a problem with my Mini - 2007 Clubman S, 60k.
I have recently changed clutch, flywheel and I did major service including oil replacement.
On the same day I realized that whole valve cover is covered by oil (please see the photo)
But it doesn't look like gasket failure as there is no trace of oil on the engine block.
The 2nd photo was taken on the day I bought the car, you can find a little bit of oil on the valve cover but not much.
I am not sure what caused such failure the only reason I can think of is the plastic cover with mini logo which isn't fixed/screwed/glued to the valve cover, is it OK or it should be fixed?
Any help will be appreciated.
Attached Thumbnails Mini throws oil over the valve cover.-mini-oil.jpg   Mini throws oil over the valve cover.-mini-engine.jpg
Old Aug 31, 2016 | 06:48 PM
slimjimtell's Avatar
slimjimtell
Your valve cover is cracked. You have to replace the entire valve cover. About 350
Old Sep 9, 2016 | 05:46 AM
+1 it needs replaced, that cover is not suppose to come off. Part # 11127646555
All the info linked here:
https://www.northamericanmotoring.co...lve-cover.html
quickcoop
Dec 4, 2020 09:05 AM
solomio
Oct 19, 2018 11:12 AM
MiniSkoon
Mar 14, 2016 12:45 PM
NYTransplant
Mar 13, 2016 11:10 AM
gomini
Jun 6, 2002 03:37 PM
