R55 How often for tune ups?
Old Dec 7, 2014 | 09:49 AM
Minime1963's Avatar
Minime1963
Anyone know how long for first tune up? Manual says 60k for S models and 100k for base models. My mechanic says 100k for either. Also, anyone know the going rate?
Old Dec 7, 2014 | 11:08 AM
Fiveostang's Avatar
Fiveostang
Idk but your car looks good with the black wheels I think I'm gonna do black on my car too.
Old Dec 7, 2014 | 12:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
From our experience:
air filter needs to be replaced about 30k miles.
Spark plugs we replace on the Turbo car every 30-40k. Seems early, but we keep finding them at 50-60 with the electrode burnt completely off.
Cabin filter once a year.
Oil change every 5k
Drive belt every 4yrs or 60k miles.
Old Dec 7, 2014 | 12:40 PM
ashchuckton's Avatar
ashchuckton
I think Way's advice should be followed.
Old Dec 7, 2014 | 09:16 PM
Minime1963's Avatar
Minime1963
Price for tune up? No Mini Cooper dealer in town. People are suggesting the local BMW dealer. They charge $95
Old Dec 7, 2014 | 09:36 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
"tune up" seems to be an outdated concept these days. Mini replaces components as the computer tells them it is needed. Air Filter, Cabin Filter & spark plugs are pretty simple DIY stuff. Oil change is a bit more involved and I take my cars to a mechanic who is more fussy about it than I am.
Old Dec 8, 2014 | 03:35 AM
mini coop's Avatar
mini coop
I just had a "tune up" on my 2008 base Mini. It's recommended at 100,000 miles and at about 100,00 miles the car started stuttering with no acceleration. It needed the old fashioned touch. New park plugs and a coil was shot. I wholeheartedly agree with frequent oil changes. This will help prevent other potential big repairs in your car.
Old Dec 9, 2014 | 05:51 PM
Minime1963's Avatar
Minime1963
I brought my Clubman in to bmw for an oil change. The service tech used my key to read the data on my car, really cool. I didn't know about this. He said I didn't need an oil change for another 6k. Is it just me, or is having a Mini Cooper more of an addiction/lifestyle than just car ownership :-D
Old Dec 10, 2014 | 01:45 PM
kmac17's Avatar
kmac17
The monitor system in the car may have a very long oil change interval programmed. Depends on the model year as they cut the interval in 1/2 at some point. If you have a S, then go with a 5k interval on the oil change. You car is worth it and you have so many fewer issues down the road if the oil refreshed.
I just changed plugs in my '12S at 61k miles. I was getting hesitation under full throttle with fun codes and going into limp mode. Seafoam'ed the intake and changed the plugs and the problem is solved. I won't wait so long before I change them again. All were out of spec and 2 were mostly gone. A dead plug will kill the ignition coil pack trying to fire it.
Cheers, Kevin.
Old Dec 10, 2014 | 09:42 PM
Minime1963's Avatar
Minime1963
It seems to me, changing your oil every 5k is a bit overkill. Especially considered it's high end synthetic.
Old Dec 11, 2014 | 03:27 AM
mini coop's Avatar
mini coop
My 2008 didn't require its first oil change, according to the computer, until 19,000 miles. That being with the synthetic oil. That is way too long regardless of driving habits. It's better to error on the frequent side rather than the infrequent side.
Old Dec 11, 2014 | 10:47 AM
Flyinace2000's Avatar
Flyinace2000
This has been discusssed endlessly, BUT assuming you drive 12k/year i think 6months/6k miles is a very reasonable mtc schedule for oil changes. Its not like changing your oil will do damage to your engine if you do it too much.
Old Dec 11, 2014 | 11:47 AM
reducati's Avatar
reducati
i have a 2012 s ...is changing the spark plugs a do it your self in an hour job?
Old Dec 11, 2014 | 11:57 AM
ashchuckton
As long as you have a torque wrench & the proper spark plug socket it is. Do your plug change on a cold engine.
Old Dec 11, 2014 | 01:31 PM
bavmotors's Avatar
bavmotors
Spark plugs and oil changes, both very easy to do, both easy to screw up. If they aren't done properly, serious issues can happen. That being said I would change the plugs every 40-50k and the oil really depends, wouldn't go further than 7k . I clean my k&n filter usually every 6 months, or replace the paper filters once a year.
Old Dec 11, 2014 | 02:00 PM
rckrzy1's Avatar
rckrzy1
I'm not going to beat the dead horse on oil changes, I tested my oil at a LAB and about 8K is the max before it runs out of the good stuff.
Plugs, yes, often. My wife had a plug drop the insulator at 36K , caused misfires, so I would say 40K plug changes on S models.
Old Dec 11, 2014 | 03:16 PM
kmac17's Avatar
kmac17
Spark plug change is very doable. Just remember you are threading into an aluminum head. Put dielectric grease on the threads, thread them in by hand using just the socket and an extension, torque to 25 ft/lbs. put some dielectric grease on the coil pack and they will be much easier to remove next time.
Cheers.
Old Dec 12, 2014 | 06:24 AM
rckrzy1's Avatar
rckrzy1
Cheers.
I use antiseize on threads, which you should do any time you put steel into alum . Grease is a good idea too, on the coil end of plug.
Old Dec 12, 2014 | 08:20 AM
kmac17's Avatar
kmac17
I used dielectric grease for the spark plug because the threads are the grounding connection of the plug and the better the electrical conducting between the plug and the head the better the ignition will be. Not sure if it's any better or worse than anti seize which is aluminum, copper and graphite.
I live in Chicago and we salt roads here. So any bolt or nut that I loosen on a car get's anti seize paste when I reassemble it. Any metal on metal contact needs something or it will fuse together over time.
Again, Cheers.
Old Dec 12, 2014 | 09:25 AM
rckrzy1's Avatar
rckrzy1
Again, Cheers.
Having been an electronic tech for over 30 yrs I can tell you that your thinking is wrong about dielectric grease. It's an insulator and will not help the grounding , we use it in RF connectors to keep water out and if it conducted that would not work, at all. If you don't believe me google it.
Dielectric grease is electrically http://en.wikipedia.org/wiki/Electrical_insulation and does not break down when high voltage is applied. It is often applied to http://en.wikipedia.org/wiki/Electrical_connector, particularly those containing rubber gaskets, as a means of lubricating and sealing rubber portions of the connector without http://en.wikipedia.org/wiki/Arcing.
And being born and raised in Chicago I know all about the cancer of cars. I don't miss that.
Old Dec 12, 2014 | 02:43 PM
ashchuckton
There are a couple of views on using anti-seize on plugs. One is use it especially on plugs going into an aluminum head. The other is don't. Plug makers say it isn't needed due to coatings applied to the threads during manufacture.
Me I use just a very tiny kiss of anti-seize on plugs. I use dielectric grease on all electrical connections.
Old Dec 31, 2014 | 09:25 AM
R55&R60_N18's Avatar
R55&R60_N18
I took Way Motor's Advice as posted above and changed my cabin filter, ordered my spark plugs, drive belt going to be installed next week when I install my new exhaust and I have an AEM CAI filter I wash clean when needed. I also keep my oil changed ever 3k miles or so.
However, I did find a pretty good mini performance shop down here and when I asked about a tune.... the mechanic told me 800 bux but I think his tune is different then what is being discussed here. I am waiting for him to come back from vacation to ask him exactly what parts are installed during this tune as I know he did mention something about it being done through the his computer at the shop as well.
Old Dec 31, 2014 | 01:07 PM
Minime1963's Avatar
Minime1963
Changing your oil every 3k is overkill, and a waste of money. The high- end synthetic oil simply does not need to be changed that often, assuming that's what you're using.
Old Dec 31, 2014 | 01:24 PM
R55&R60_N18
yeah I use the Synthetic. I was told it is overkill lol
I figured if Mini Dealership won't change it for like 8 months... I might as well just do it myself =/
Old Jan 1, 2015 | 08:44 AM
Minime1963's Avatar
Minime1963
Good for you though. Better safe than sorry.
Happy motoring!
Sep 4, 2015 02:12 PM
The_Kid
Aug 28, 2015 04:50 AM
dscott90000
Aug 24, 2015 08:54 AM
maytulip32
Aug 19, 2015 12:49 PM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
