R55 Suspension Question
Old Jun 6, 2014 | 11:50 AM
MiniMaestro's Avatar
MiniMaestro
Suspension Question
I have a club member with an R56 selling his JCW Suspension. Does anyone know if there will be any issues putting it on my R55 Clubman? Has anyone done this?
Thanks!
-Adam
Old Jun 6, 2014 | 12:09 PM
hsautocrosser's Avatar
hsautocrosser
Is it a dealer/port installed JCW suspension or the stock suspension from a JCW? If the latter, I would expect no benefit from it.
Old Jun 6, 2014 | 02:46 PM
MiniMaestro
Upgraded suspension
Old Jun 6, 2014 | 06:24 PM
hsautocrosser
The springs supplied for any type suspension on any MINI are dependent on the weight of installed options on the idividual car and likely differ between models as well. I was going to suggest that you ask a dealer if the other parts of a JCW suspension are different for Clubman vs JCW, but I see no JCW suspension accessory available for a Clubman on MINIUSA.COM. None has been made available for a Roadster either due to insufficient demand. A part number comparison of stock suspension parts could be made at REALOEM.COM to determine if they are the same.
If you get a more definitive answer I'd be interested in seeing it as a Coupe JCW suspension may just find it's way onto my Roadster in the future.
Old Jun 9, 2014 | 08:44 PM
crashmtb's Avatar
crashmtb
Shocks and particularly the springs are different between R56 and clubman. Won't work well.
There's no aftermarket JCW suspension kit for the clubman. I checked. Ended up doing Koni FSD and Eibach pro-kit springs, on my non-S 2009.
Old Jun 10, 2014 | 07:05 AM
pjv1k's Avatar
pjv1k
Originally Posted by crashmtb
Shocks and particularly the springs are different between R56 and clubman. Won't work well. There's no aftermarket JCW suspension kit for the clubman. I checked. Ended up doing Koni FSD and Eibach pro-kit springs, on my non-S 2009.
How do you like that set up?
Old Jun 10, 2014 | 07:32 AM
MiniMaestro
Thank you all for your feedback and as crash and hsauto have both stated they will attach but the weight differences (the ones that were for sale were of a hatch with no sunroof, mine has a sunroof to boot) would have not made for a proper set up.
Much appreciated!
Old Jun 11, 2014 | 02:55 PM
bratling's Avatar
bratling
Super Moderator
I too am curious, since the Koni FSD aren't meant to be used with lowering springs!
twistedimages
Sep 19, 2024 04:13 AM
silence2-38554
Nov 12, 2015 09:39 AM
Kahnfucious
Aug 15, 2015 08:43 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
