R55 2014 Clubman Spare tire
Old Dec 30, 2013 | 07:12 AM
clubbie's Avatar
clubbie
After waiting since October,my new Clubman S should arrive in the next week or so... I want to get a spare tire for it, and this is my question: Will a regular sized tire fit in the boot so I would not have to switch back to front like you have to with the Mini Donut spare? The car is ordered with 17" rubber...
Old Dec 30, 2013 | 07:17 AM
danjreed's Avatar
danjreed
Nope, you have to use the donut spare. And it will only fit in the rear wheels.
Old Jan 1, 2014 | 06:40 PM
bugeye1031's Avatar
bugeye1031
Moderator
In addition to the donut spare, I had to get a jack and a different styrofoam "tool holder" spec'd for a MINI with 15 inch wheels that came with a space saver spare.
Old Jan 3, 2014 | 04:44 AM
mattkosem's Avatar
mattkosem
I didn't need to get a jack for my 2013. I just ordered the wheel kit and foam piece from Detroit tuned. Everything else moved right over from my stock piece of foam.
--Matt
Old Jun 26, 2015 | 10:46 AM
cargusjoh's Avatar
cargusjoh
EDIT:
Reading deeper into the forum My question is answered, thanks
ORIG" traveling or I would look in the manual.. Double check, spare tire only works in the rear?
Old Jun 26, 2015 | 11:46 AM
mashby's Avatar
mashby
Originally Posted by cargusjoh
EDIT:
That's correct. And you need an adapter if you have the big brake kit.
Old Jun 28, 2015 | 04:56 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here is the spare that fits the well.
http://www.waymotorworks.com/mini-spare-tire-wheel.html
and for the JCW brakes you need this spacer kit
http://www.waymotorworks.com/jcw-bra...pacer-kit.html
Old Sep 19, 2015 | 08:57 AM
6thGear's Avatar
6thGear
EDIT:
This is the safest and recommended way of using any Donut spare on a FWD car. You never want to have a donut in the front because it can cause steering/handling issues more than if it is in the back. This stinks because it means if you have a flat in the front, you should swap the back good tire to the front before replacing with the donut in the back.
Old Sep 19, 2015 | 09:25 AM
cargusjoh's Avatar
cargusjoh
Thanks! I'll do it this way if I get a flat
kazyn
Oct 25, 2019 02:34 PM
madmax88
Aug 21, 2017 07:07 PM
SosoMINI
Nov 22, 2015 03:17 PM
TJANK
Aug 24, 2015 06:11 PM
Mrdi
Aug 7, 2015 01:06 PM
