R55 Heater core fitting leaking
Old Sep 20, 2015 | 05:25 PM
Redhotz's Avatar
Redhotz
I have been having a leak by my gas pedal and I took off the kick panel and noticed that the lower heater hose is leaking at the O ring going into the heater core. Should I replace the O ring or put some radiator sealant in?
Old Sep 21, 2015 | 12:55 PM
Replace the o ring and get the mounting set comes with it and it will make sure that the plastic is seated and not cracked. 64113422668
https://www.ecstuning.com/Search/SiteSearch/64113422668/
Old Sep 22, 2015 | 09:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Do NOT put sealer in the cooling system. It just plugs things up and makes things worse.
Replace the seals and plastic clips it's pretty easy job, just drain the coolant so you don't get it all in the carpet.
We got the seal kits
http://www.waymotorworks.com/heater-...7-r58-r59.html
W0TM8
Dec 19, 2019 07:50 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
