R55 Coolant leak
Old Oct 22, 2013 | 12:45 PM
roach_juts's Avatar
roach_juts
Coolant leak
hello,
just bought a used 2009 mini clubman last sept28 2013
now i see some small amount of fluids every time i use it
i did check the fluid it feels like its leaking some coolant,
i did check mg reservoir its almost in the minimum level already
i see there's this canister below the reservoir & i am thinking that the coolant is coming from there, or its just catching the drop from the reservoir
need some advice please what to do
and any specific coolant i can buy from pepboys or autozone?
i dont want to go to the dealer yet, if i can do a quick & easy fix
that will be my last option, since i dont have any extended warraty
Thanks !!!
Old Oct 22, 2013 | 03:09 PM
bigcooper666's Avatar
bigcooper666
You should buy mini approved coolant from your local mini delaer
p.s. It prolly needs a waterpump there are known to go and there is an updated one
happy motoring
remember to check your oil
Old Oct 22, 2013 | 04:12 PM
roach_juts's Avatar
roach_juts
Thank you for the quick reply
i saw a article that my culbman has a recall
i hope this recall helps me with $$$
http://www.autoblog.com/2012/01/16/m...er-water-pump/
Old Oct 23, 2013 | 01:10 PM
roach_juts's Avatar
roach_juts
Thanks for the quick reply
i hope its the water pump, & i can claim it as a recall
Old Oct 29, 2013 | 07:49 AM
Josh Rogers's Avatar
Josh Rogers
Could be the thermostat housing. This is a common problem on the minis. Happened with mine. I wish someone would come out with a metal one instead of this cheap plastic.
Old Oct 30, 2013 | 06:45 AM
Andrew Zeif's Avatar
Andrew Zeif
Coolant leak
Definitely check out the thermostat housing..My 2009 Clubman's temperature gauge suddenly went red on the middle of a busy NYC bridge and then stalled a bit later. Turns out 100% of the coolant leaked out around the temperature housing and now my engine is wrecked......PS Mini-USA as of this writing is refusing to help and told me that this sort of catastrophic engine damage can be expected form time to time when a car gets to 70K miles.....
Old Oct 30, 2013 | 11:40 AM
roach_juts's Avatar
roach_juts
damn, my clubman is about 76k miles,
right now the coolant leak stop, i did check the reservoir,the hose that connect to the thermostat housing, are all dry & the level of coolant is at max level...
ill be bring my in my chubby to a dealer, to have the recall of the thing recall
and have everything check ..
Thanks for all the info's
Old Oct 31, 2013 | 06:35 AM
v10climber's Avatar
v10climber
If it's on the drivers side of the car it's likely leaking from the thermostat housing. It's a fairly well known problem.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
