R55 My 2010 Clubbie needs a new Turbocharger
Old Sep 17, 2010 | 04:59 PM
RockyRoad's Avatar
RockyRoad
Two weeks ago, my clubbie developed a whistling noise when I accelarates between 2000 to 3500 RPM. I took my car to the dealer this morning to have it check.
I got a phone call from my SA and gave me the news. The whistling noise was coming from the turbocharger and needs to be replace. I was surpise! My car only has 9,100 miles, and I don't track or even drive it hard. I pretty much babied my car since I took delivery.
For those of you who drives a MINI with turbo, do you have any tips to prevent the turbocharger from being damage or to help prolong the life of the turbo?
I'm not sure if this is still an old school practice. When the car is cold, I usually let the engine to warm-up for 5 mins before driving it, and let the engine running for 3 mins before shutting it off to cool-off the turbo.
Old Sep 17, 2010 | 05:08 PM
MCS Fever's Avatar
MCS Fever
Idling is actually hard on any engine - and the environment....
Old Sep 17, 2010 | 05:16 PM
MINIdave's Avatar
MINIdave
Your MINI uses a water cooled turbo, so you don't need to warm it up or let it cool down, especially since you don't track your car. Even if you did, it still isn't necessary as there's a water pump that continues to circulate coolant thru the turbo after the engine's off, if it's hot enough.
Bottom line, there's probably nothing you can do other than regular oil changes (have you had your's changed in the 9100 miles you've driven?) to prolong your turbo's life - trucks routinely get 300,000 to a million miles on theirs so it's not just that the car has a turbo on it, and there's no reason to baby it. You use the turbo constantly, even tho you don't floor it - it makes boost any time there's load on the engine - starting from a stop, going up even a slight incline, any time you're on the hiway and so on.
I change my oil (using a factory filter and Mobil1) every 7500 or so, just for insurance.....
Old Sep 17, 2010 | 05:21 PM
RockyRoad's Avatar
RockyRoad
So what you are saying don't bother warming-up the engine. Basically, drive the car and go even it is still cold.
Why idling is actually hard on any engine?
Old Sep 17, 2010 | 05:26 PM
MCS Fever's Avatar
MCS Fever
30 secounds and head out easy even in freezing temps. That's what I do, even with my diesel truck - actually especially with a diesel - A diesel is such an air pump it loses heat at idle.
Here's an web site about it - don't agree with shutting a warm engine off at drive-thru's etc like they recommend really, seems like too much wear and tear on the starter and battery.
http://www.consumerenergycenter.org/myths/idling.html
Myth #1: The engine should be warmed up before driving. Reality: Idling is not an effective way to warm up your vehicle, even in cold weather. The best way to do this is to drive the vehicle. With today's modern engines, you need no more than 30 seconds of idling on winter days before driving away.
Myth #2: Idling is good for your engine. Reality: Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. Fuel is only partially combusted when idling because an engine does not operate at its peak temperature. This leads to the build up of fuel residues on cylinder walls that can damage engine components and increase fuel consumption.
Old Sep 17, 2010 | 05:29 PM
RockyRoad's Avatar
RockyRoad
MiniDave - I changed the oil @ 1.5k and 5k using factory filter and Mobil1 (5w/30).
Old Sep 17, 2010 | 05:33 PM
RockyRoad's Avatar
RockyRoad
Thanks MCS Fever. This is really useful information.
Old Sep 17, 2010 | 05:42 PM
MCS Fever's Avatar
MCS Fever
I use to idle my diesel all the time in the winter at rest stops, couldn't figure out why the engine was colder than when we stopped. Fuel consumption wise though, a diesel uses very little fuel at idle compared to a gasser.
Not a huge deal with such short oil change intervals, but the only Mobil 1 rated for MINI to use is 0W/40. I think you will see an MPG increase with it to boot. Great oil, I run the 0W advanced fuel economy oils in all my gas engines.
http://www.mobiloil.com/usa-english/...l_1_0w-40.aspx
Old Sep 17, 2010 | 09:04 PM
Benibiker's Avatar
Benibiker
Did they say why the turbo failed? A blown seal, broken vane, bad bearings? I'm sure it wasn't anything you did or didn't do, it just failed...
Old Sep 17, 2010 | 10:15 PM
RockyRoad's Avatar
RockyRoad
According to my SA, the turbo did not failed. It just developed a whistling noise which could mean some particular part inside the turbo went bad.
Old Sep 18, 2010 | 11:30 AM
mbu's Avatar
mbu
At least your dealer is fixing the problem by replacing the entire turbo under warranty instead of trying to "nitpick" the problem! Who's the dealer?
Old Sep 18, 2010 | 11:43 AM
Benibiker's Avatar
Benibiker
I my book if it's doing something it's not suppose to then it failed. Glad it's getting replaced.
Old Sep 18, 2010 | 06:13 PM
yetti96's Avatar
yetti96
Did they ask you what oil you used? I don't think that would have effected the life of the turbo but just keep that in mind for the next change, get it back to spec.
Old Sep 19, 2010 | 01:28 AM
RockyRoad's Avatar
RockyRoad
East Bay MINI, Located in Pleasanton, CA.
Old Sep 19, 2010 | 01:33 AM
RockyRoad's Avatar
RockyRoad
No, they did not ask any question regarding the type of oil I use. Even though they ask, I use Mobil 1 5w-30 Syn.
Old Sep 19, 2010 | 10:56 AM
MINIdave's Avatar
MINIdave
Well, lets hear it for a proactive dealer!
Instead of waiting for it to fail completely, they decided to change it out now while it's just making a noise - good for them!
Chances are it's just a bad bearing, that's all.
Old Oct 27, 2010 | 10:35 AM
JohnGuy's Avatar
JohnGuy
My Turbo failed at 28,000 miles on my 2008. They said sludge was the problem. After investigation they determined it was not my fault. It cost something in the range of $3,500. Makes me wonder about the reliability in the future especially after the warranty expires.
Old Oct 27, 2010 | 12:27 PM
TheBigNewt's Avatar
TheBigNewt
I was waiting for the time-honored dealership line "you used bad gas" lol. I love that one. If you hear it head straight for another dealer.
Old Oct 27, 2010 | 02:18 PM
ngweibing's Avatar
ngweibing
like they said... at least dealership is handling it..
Old Nov 1, 2010 | 01:17 PM
beasleyboy's Avatar
beasleyboy
It's also very bad for your muffler. Tip: kill the engine if you're stopped at a railroad crossing and you know you'll be stuck there six minutes. I seriously wonder, how much fuel does a Ford Expedition V8 slurp when idling that long?
Old Nov 5, 2010 | 05:25 PM
turbotraveller's Avatar
turbotraveller
There is no need to idle the car to cool the turbo down. A thermostatically controlled pump continues to pump coolant through the turbo until it is cooled down. You can hear the pump running after the ignition is shut off.
Old Nov 8, 2010 | 09:17 AM
rexicon's Avatar
rexicon
I had 2 K04 Turbos go out on me in my old VW GTI and both times they whistled before dying a very smokey death...
The cause of my failures was the oil bearing getting too hot which in turn led to the turbo shaft bending and the turbo vanes hitting the housing. Once they started to whistle it was a very short time before the shafts broke which then dumped all of the oil under pressure from the oil bearing straight into the exhaust manifold. The ensuing smokescreen would have made 007 proud!
Old Nov 8, 2010 | 07:16 PM
GOESP's Avatar
GOESP
Funny you mentioned your GTI. Mine was whistling for a while until recently.
Just had to add a little more oil.
mauiguyharry
Oct 8, 2015 06:53 PM
Oct 1, 2015 12:13 PM
M7Speed
Oct 1, 2015 07:05 AM
aldito2
Sep 30, 2015 10:44 AM
EVMini
Sep 28, 2015 10:20 AM
