R55 Jack Pads for Jack Stands - Location?
Old Aug 12, 2010 | 12:00 PM
bluefox280's Avatar
bluefox280
When doing home wheel / suspension / brake projects, I have easily located the lifting "block" on the frame.
However, where is the proper location for setting a jack stand underneath while lifting on the "block"?
Are there available jack pads to install on the unibody / frame?
- Erik
Old Aug 12, 2010 | 12:29 PM
grgramps's Avatar
grgramps
Erik, I've had my Mini for just a month and have been wondering the same thing! Thanks for posting the question - now there are 2 of us wanting to know.
Old Aug 12, 2010 | 12:54 PM
HRM's Avatar
HRM
They way it is done is to not use the jack points to get the car up. People use a board in the center to spread the weight, then when it is up, they use the jack points for the stands.
There are threads, even some with photos about the method.
Old Aug 12, 2010 | 07:58 PM
bluefox280's Avatar
bluefox280
I found [several] those, and to be honest, was blown away that that's the "best solution" that's been presented.
My cheaper VW has seperate jacking and support points so you can lift each corner / side without damaging sideskirts or trim.
Please, PLEASE say there's a better way.
- Erik
Old Dec 7, 2017 | 01:34 PM
MrFunk's Avatar
MrFunk
- Erik
Nope. I think that is your best technique. New cars are not designed to be DIY friendly.
Old Dec 7, 2017 | 04:05 PM
Capt_bj's Avatar
Capt_bj
resurrection award ... previous post is from 2010
Old Dec 7, 2017 | 09:52 PM
Fly'n Brick's Avatar
Fly'n Brick
It does make you wonder about the outcome though, doesn't it. BlimeyCabrio's blog page on 'How a stud lifts a MINI' should be required reading.
Old Dec 8, 2017 | 04:39 AM
Whine not Walnuts's Avatar
Whine not Walnuts
ModMini has a good video on jacking up the car with a 2x4. MINI is stiff enough that you can lift the entire side up and put both your stands in place.
Least of my worries is jacking the car up. The bigger PIA is working on car while sitting crosslegged on the floor or on your back trying to move you hand around when your shoulder is not double jointed.
thebordella
Aug 31, 2015 01:37 PM
1Marine
Aug 24, 2015 05:43 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
