R55 Clubman Reverse Lights
Old May 8, 2009 | 09:30 AM
JohnJohn's Avatar
JohnJohn
I don't have a rear fog light in my '09 Clubman. I assume I still have just one reverse light? If there a solution out there to get more light?
I was backing out of my garage last light and I couldn't see anything.
- add a light?
- change the bulb?
- wire up the other light?
- duct tape a Mag Light to the roof?
Thanks.
Old May 8, 2009 | 09:54 AM
schatzy62's Avatar
schatzy62
- add a light?
- change the bulb?
Thanks.
What you can do is order the UK drivers side rear light assembly and that will have the white backup light space. The fog light has to be on the opposite side from the curb. I am not sure if the bulb socket is the same for both bulbs but you should be able to get one to anyway so that you do not need to cut the socket off the fog light wires.
I doubt your local dealer will be able to get it for you as they can not get parts for foreign models but you could contact a dealer in the UK and have it sent over.
Old May 8, 2009 | 09:23 PM
minimarine's Avatar
minimarine
I'd like to do this too (making symmetrical reverse lights). I didn't realize the UK lights were reversed like that. It would probably take some wiring work, but I'm sure it can be done.
Old May 8, 2009 | 10:15 PM
crashmtb's Avatar
crashmtb
The reverse light is like highlander. THERE CAN ONLY BE ONE
Old May 9, 2009 | 05:50 AM
schatzy62's Avatar
schatzy62
just tap off of the original light and run the wires to the other side and there you have it done. But only if you have a clear lens on the ohter side.
Old Jul 1, 2009 | 12:23 PM
godskid's Avatar
godskid
Has anybody created a kit for this yet? I have a 2009 Clubman (USA), no fog light, and would like to have two backup (reverse) lights. Somebody -- make it simple for us!
Old Jul 1, 2009 | 03:48 PM
schatzy62's Avatar
schatzy62
Read post # 2 of this thread it tells you exactly how to do it.
Old Jul 1, 2009 | 03:58 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Has anyone checked to see if there is just a wire sitting idly on the other side rather than running a wire across the width of the car?
Knowing MINI they probably have the car wired for both the euro and american versions which would mean you just find the correct wire and plug it into the harness.
Just a hypothesis.
Old Jul 1, 2009 | 04:16 PM
schatzy62's Avatar
schatzy62
Just a hypothesis.
Unfortunately the wiring harness for the left hand and right hand drive cars is different. At least on my April 08 build that is.
Old May 10, 2010 | 11:05 PM
Vinyl Styles's Avatar
Vinyl Styles
I'm gunna look into getting a hold of that UK tail light.
Does anyone know the reverse light bulb number? 7507? Same as 1157?
Old May 10, 2010 | 11:22 PM
rkw's Avatar
rkw
The Owner's Manual says the bulb is P21W, which should be equivalent to 1156.
Old May 12, 2010 | 09:42 AM
dewarner's Avatar
dewarner
I put a PIAA replacement bulb in the backup light socket of my 2009 MCCS, and it is definitely brighter than the standard bulb.
Old May 13, 2010 | 08:27 PM
colejd's Avatar
colejd
dewarner,
What is the PIAA bulb number for that MCCS backup light?
Old May 13, 2010 | 10:56 PM
rkw's Avatar
rkw
The wiring for both taillights run to the footwell module (at the drivers footwell). I think you can probably do a straight swap with a left side UK taillight (use the existing connector and wiring). Then take advantage of the rear fog wiring but jumper it to the backup signal, up at the footwell module. In that way, you only add a short jumper wire and avoid running a new wire across the width of the car.
Old May 14, 2010 | 05:38 PM
dewarner's Avatar
dewarner
The PIAA bulb for the backup light is 1156. They come as a set of two.
Old May 15, 2010 | 12:00 AM
Vinyl Styles
Nice!
Sounds confusing tho LOL.
I may need some help with this once I track down that UK tail light.
Old Feb 14, 2011 | 12:47 PM
Vinyl Styles
Old Feb 14, 2011 | 12:59 PM
minimarine's Avatar
minimarine
@Lagston - Looks great!
It's hard to tell from the photo (if they are on or not), but are both reverse lights wired up? If so, did you use the jumper, or wire it across the back.
I'm considering upgrading to the new LED tail lights for the 11 Clubmans and figure that might be a perfect time to do the dual reverse lights as well.
How hard was it to get the UK left tail light?
Old Feb 14, 2011 | 01:07 PM
3pedalMINI's Avatar
3pedalMINI
That looks fantastic! I thought i was the only guy that thought about tinting the 3rd brakelight, i guess not
like the above poster, how hard was it to source the UK tail light?
Old Feb 14, 2011 | 09:25 PM
Vinyl Styles
Thanks!
We wired it across to the other reverse light.
The tail light was easy to get. We ordered it from coolministuff.com
Around $130 USD if I recall.
Old Feb 14, 2011 | 11:15 PM
mini-mon's Avatar
mini-mon
lagston when are you guys coming down to SoCal.......
Old Feb 15, 2011 | 04:27 AM
Clubmaste00's Avatar
Clubmaste00
Lagston
Are you sure it was from Coolministuff.com? Just visited their site and do not see any mention of a taillight or other mini parts for that matter.
Dennis
Old Feb 15, 2011 | 05:05 AM
Rally@StanceDesign
Originally Posted by Clubmaste00
Lagston
Dennis
I'd bet that he meant www.newministuff.com rather than 'cool'
Great work Lyle.
Old Feb 15, 2011 | 06:02 AM
MINIxB's Avatar
MINIxB
Here is the direct link: http://www.newministuff.com/new/shop...uctshow&id=804
Old Feb 15, 2011 | 03:07 PM
Vinyl Styles
Aaahh, yup thats it.
@mini-mon - We don't have dates set for a SoCal trip yet. We will be fairly busy these next few months; Europe, New York, AMVIV, Chicago....
SoCal may be June.
